What is YUV 4:2:2 16 bits Video bit field format ?
According to the Table 4-9 in UG1037, There is two byte YUV 4:2:2 format (VF Code = 0).
The first byte contains V/U (Cr/Cb), and the second byte contains Y.
What is YUV 4:2:2 16 bits Video bit field format (first byte)?
Does it consists of 4 bit V and 4 bit U? or interleaved bits?
Question #2.
I want to draw a picture using a tool, and I want to convert the picture into above YUV 4:2:2 16 bits Video Format.
Would you recommend the drawing tool and the conversion steps?
The result is an byte array in C code as follows.
unsigned char  Image[2621440] = { 0x80,0x00, ... }
I will really appreciate if I can be given the answers.
Thank you very much.
Mentor
Mentor
Re: What is YUV 4:2:2 16 bits Video bit field format ?
Hi @pnk004
Q1)
It's an interleaved.
Would you refer ITU-R BT656 or BT1120 (digital video standard) ?
Q2)
I recommend to refer the above standard, too.
[note]
1)
YUV 422 (ITU BT.656 and BT.1120) has an offset value on V/U as 0x80 (if color depth is 8bit and using video streaming mode).
2)
Here is an example for C code.
// Y0, Cr0, Y1, Cb0, ....
(unsigned char) Image[xxx] = { 0x10, 0x80, 0x10, 0x80, ....}
Best regards,
Mentor
Mentor
Hi @pnk004
Q1)
Q2)
[note]
1)
2)
Best regards,
Dear Watari.
Thank you very much for your kind answer.
