What is the decoded output of a video codec?
someone can explain to me what exactly is the output of video decoding. Let's say it is a H.264 stream in an MP4 container and how to give decoder output to display port?
Re: What is the decoded output of a video codec?
Hi sy5809358@gmail.com
This is because you didn't set any location constraint for the port pll_ref_clk. Again the BSP design has the full desing ready
Florent
The decoded video stream will be stored in memory. You can send it through displayport via the DPDMA.
For ZCU104 or ZCU106 (using the BSPs), there are some VCU Out of the Box examples available in PG252 from page 133.
The example Decode -> Display is doing what you want to do.
Florent
In example1 decode -> display there is no block design.how can i do?
The vivado project with the block design is integrated in the BSP. Just create a new petalinux project with the BSP as source and you can see the vivado design in the hardware folder.
Note that the block design is really simple. You mainly have the VCU. The output is the Displayport controller which is inside the PS (Zynq MPSoC).
Florent
i implemented blockdesign for video decoding using videocodec.but i got the errors.is it ok or any another blocks need to add? this example i taken from the videocodec unit userguide..in this block diagram where decoded data can store..please explain me.
HI sy5809358@gmail.com
What error do you get? Yes your design should be fine.
You might want to start directly with the BSP. It has everything you need.
Florent
synthesis and implementation completed successfully.Errors are occured while generating bitstream..i attached the screenshot.
Florent
i already added the constrain file and i mention the pin for pll ref clk.
Are you sure the location is correct and not already used by another in/out?
You might want to have a look to your critical warnings and warnings, there might be more details about it
Florent
thank you.bitstream is generated successfully.can u explain me where the decoded video is stored..what is the use of mcu?now i want to display using display port.from where can i take decoded output.
[Florent] - This is stored into the PS DDR. The exact address should be defined in the device tree. Once again, look at the BSP for an example
[Florent] - The MCU is a microcontroller inside the VCU to control it. From the MPSoC processor you only send high level command. The MCU coontrol completely the VCU
[Florent]  - You might want to use a gstreamer pipeline to avoid any complexity. As mentioned previously, there is an example in the PG252 from page 133 which does that.
Florent
Decoded video stored in ps ddr means no need to mention any block in the design is it right or wrong.earlier i posted the block design is it enough or any blocks are needed for decoding..in the pdf i cant get the exact address..please help me.
can u explain me....how to read and write from memory using s_axi_hp1_fpd and s_axi_hp2_fpd?how to set one for read operation and another one for write operation?
Please use the ZCU104/ZCU106 BSPs + PG252 as a reference. This should have all the information you need
Florent
