Observer ain0102
What signal should be connected to VDMA to mm2_cfync?
Hi.
I use Zedboad and FMC-HDMI modules.
HDMI inputs were connected to VDMA write channels, and VDMA read channels were connected to HDMI outputs.
What should be connected to VDMA mm2_cfync?
I need help.
Thank you.
Re: What signal should be connected to VDMA to mm2_cfync?
You Should put the S2MM channel in 'TUSER" mode for fsync.
Synchronization between read and write sides happens via the genlock mechanism.
www.xilinx.com
You should put the MM2S side in free-run mode in most cases (thus no fsync connection will be required). Timing will be derived from downstream VTC/AXIS2VideoOut cores.
www.xilinx.com
Observer ain0102
Both the write channel and read channel have entered the free run mode.
How do I synchronize the writing channel with the reading channel?
www.xilinx.com
Hi @ain0102,
Do you have any updates on this?
If  everything clear for you on this subject, please kindly close the topic by marking one reply as accepted solution.
Thanks and Regards,
Florent
