Visitor cor
Where can I find the vid_edid_v1 IP?
I have to integrate the DisplayPort IP into my design. Therefore I'm studying the Video DisplayPort 1.4 RX Subsystem example (the RX only example on ZCU102 board).
One of the IPs used in this example is the vid_edid_v1. It simulates the IIC Edid ROM. Is it somewhere available?
Thx
Re: Where can I find the vid_edid_v1 IP?
HI @cor,
The vid_edid is what we call a helper IP. It is available only in the example design. The use of this IP outside the example design is not supported and the user is expected to write his own edid.
With that said, if you start your design from the example design you will be able to use it. However, keep in mind that it is not supported and that you are expected to write your own IP
Florent
Scholar watari
Hi @cor
I can not catch your question.
I guess your question is below.
- Know the format of EDID
- How yo describe EDID data in ROM ?
If my understanding is correct, would you refer the following wiki site ?
https://en.wikipedia.org/wiki/Extended_Display_Identification_Data
If my understanding is not correct, would you show more detail ?
Best regards,
Visitor cor
Sorry if I was not clear. I would like to instantiate a vid_edid in my design, but It is not in the IP library. And when trying to get to the documentation of it, I get an 404 browser error (the page does not exist).
So is that IP available somewhere?
HI @cor,
Florent
