XAPP1248 : Does this support 720 30fps & 1080 30fps
Does this application support input of 1080 30fps resolution?
If yes, What are the things to be taken care in design/application?
Vinay
Vinay Shenoy
Tags (2)
Re: XAPP1248 : Does this support 720 30fps & 1080 30fps
Hello @vinay_shenoy,
As per the table 11, the xapp1248 supports 1080p30:
However, for 720, this is done following the SMPTE ST 296 standard
And the SMPTE ST 296 standard defines only 720p50 and 720p60
Florent
Florent
