Visitor ddanapal
XAPP894 MIPI D-PHY IP Core support on Virtex Ultrascale
Hi there,
  I'm planning to implement the MIPI CSI interface on our Virtex Ultrascale XCVU440-FLGA2892-2-I FPGA platform based on XAPP894.  The plan is to use the Xilinx MIPI D-PHY IP Core with components from Meticom.  However, I found that I'm unable to generate the MIPI D-PHY IP Core if I have a Virtex Ultrascale part selected in Vivado.
  I do see that Xilinx mention that Ultrascale is supported through XAPP894 in the following video:
  https://www.youtube.com/watch?v=uCEcz6JiaBk
  Is there any fundamental reason why the MIPI D-PHY IP Core is not supported on Virtex Ultrascale?  I am able to generate it for Virtex 7 but I would assume that there will be differences in the primitives used between Virtex 7 vs. Ultrascale.  We really need to use the MIPI D-PHY IP Core on XCVU440 to fit the rest of our design.
  Please advise.  Thank you.
Re: XAPP894 MIPI D-PHY IP Core support on Virtex Ultrascale
Hello @ddanapal
Unfortunately, Xilinx MIPI IPs does not support UltraScale.
Please consider to use 7-series (with external PHY i.e Meticom) or UltraScale+ devices (that have native MIPI D-PHY support).
Or you may want to contact Nortwest Logic to find out whether their MIPI IP can target Xilinx UltraScale devices.
Best regards
Leo
Hello @ddanapal
Best regards
Leo
Hello @ddanapal,
Are you happy with the reply provided by @karnanl. If yes, could you kindly mark it as accepted solution (button accept as solution below the replied when you are logged in).
Thanks and Regards,
