Xapp1287 - HDMI - Key Utility Application
I am woking on xapp 1287 - HDMI 2.0 Implementation on Kintex-7 FPGA GTX Transceivers.
On page 26, Programming the HDCP keys, you describe the steps how to write the HDCP keys into the EEPROM using the key utility application.
Where can I find this application (hdcp_key_design, hdcp_key.bit,...)?
I did not find anything in the reference design folder of xapp 1287.
Thanks for your help,
Hermine.
Re: Xapp1287 - HDMI - Key Utility Application
Hello Hermine,
This issue has been fixed. You need to re-downloaded xapp1287.zip from xilinx.com, the folder called key_utility is inside the zip file.
Cheers
Hi Hermine (@deltaxlx),
Indeed, the bitstream is missing in the reference design. It should be added latter
Currently, the only way to get it is to contact marketing or your FAE.
OK thank you for your answer.
Hermine
Hello Hermine,
Cheers
Ok great, thank you!
