Observer laurencebarker
Xilinx I2S IP
My design will use an Artix 7 FPGA with a TLV320AIC23B codec. the TLV32 has both ADC and DAC, and has a common bit clock (BCLK on the data sheet). Xilinx provide separate I2S transmitter and receiver cores, each of which generates an SCK bit clock signal. For both to work, the SCK signals would need to have the same phase.
is there any way to synchronise the TX and RX cores so that I can use SCK from one core to the TLV320 please?
Observer cbanvill
Re: Xilinx I2S IP
The I2S transmitter and receiver can be configured to be master or slave with regards to the clock signals. However, this option is not present in the configuration GUI.
To change an I2S core configuration to slave (master is the default), select the core in the BD diagram, go to the 'Block Properties' Window, click on the 'Properties' tab, expand the CONFIG property and set the C_IS_MASTER property to 0.
If you are not using an IPI BD, go to the Source->IP Sources tab and select the IP that you want to modify. Then follow the same instructions in the 'Source File Properties' Window.
Visitor ozatarain
Re: Xilinx I2S IP
I also have the same problem, did you find a way to synchronize the TX and RX cores?
Newbie becky298
Re: Xilinx I2S IP
Well, I am still finding the solution. Same problem :(
Observer cbanvill
Re: Xilinx I2S IP
Re: Xilinx I2S IP
Hi @cbanvill,
Thank you for sharing your solution to get the slave mode. I have only one clarification for add: The slave mode is not yet supported by Xilinx. The user is responsible for its characterization. In fact this is the reason one the option is hidden from the GUI.
Best Regards,
Florent
Observer cbanvill
Re: Xilinx I2S IP
Hi Florent,
Thank you for the clarification. This is a bit surprising since the I2S receiver core example design is using the slave mode!
Re: Xilinx I2S IP
Hi @cbanvill,
I completely agree. I already made the same comment to development.
From my point of view, if it is used in the example design it should be supported. Thus I already requested to get official support.
However, the current status is as per the Product Guide for the IP. I.e. The core in Slave mode is not supported yet.
Best Regards,
Florent
Re: Xilinx I2S IP
Hi @laurencebarker,
Is everything clear for you on this subject?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
Re: Xilinx I2S IP
I've clicked "accept as solution" but I had by then written Verilog code to provide an I2S interface. I would have preferred catalogue IP, but I got there.
