Xilinx MIPI CSI2 RX subsystem IP 4.1 SOF is asserted at the third pixel besides the first of the frame.
Similar to https://forums.xilinx.com/t5/Video/MIPI-CSI-RX-Subsystem-SOF-stays-asserted-for-two-beats/m-p/1047754#M29056
In  https://www.xilinx.com/support/documentation/ip_documentation/axi_videoip/v1_0/ug934_axi_videoIP.pdf we see the following
Start of Frame Signal
The start of frame (SOF) signal is physically transmitted over the AXI4-Stream TUSER0 signal, and signifies the first pixel of a video field or frame. The SOF pulse is one valid transaction wide, and must coincide with the first pixel of the field or frame. SOF functions as a frame synchronization signal, allowing downstream cores to reinitialize, and detect the first pixel of a field or frame.
In a simulation (or Logic analyzer) waveform we see:
Configuration:
It can also be reproduced by simulating the MIPI CSI2 TX subsystem example design, and adding the TUSER signal to the waveform.
Re: Xilinx MIPI CSI2 RX subsystem IP 4.1 SOF is asserted at the third pixel besides the first of the frame.
Hello @wgabor
I will confirm and give you feedback on this thread.
Thanks and regards
Leo
Hello @wgabor
It seems your report is correct. I can also reproduce the issue using MIPI CSI-2 TX simulation.
It seems that in some MIPI CSI-2 RX Subsystem configuration TUSER and TLAST can be asserted for multiple beat.
I will update this thread mid of next week.
Leo
Hello @wgabor
Patch solution for this issue is provided in
   AR#73100
   AR#73099
( ARs will be published early next week )
Could you please try this patch ?
Please note that after aplying the patch to Vivado you need to remove the pre-compiled library option in vivado.
Project Manager-> settings->IP-> unselect “Use Precompiled IP Simulation Libraries” -> rerun simulation
Alternative option is to add TCL command as follow
set_property sim.use_ip_compiled_libs 0 [current_project]
Thanks & regards
Leo
Hello @wgabor
Do you have any updates on it ? Did you try to apply the patch to 2019.1 ?
https://www.xilinx.com/support/answers/73100.html
Thanks & regards
Leo
