YUV 4.2.2 to RBG using Scalar vpss
Dear all
Great day !!
I have created a design with SDI input and output through PS DP for ZCU7E custom board.
I am scaling down the input resolution to 720p, & I would like to know how to do the YUV 4.2.2 to RGB convertion using the scalar I.P
regards
Gagandeep
Re: YUV 4.2.2 to RBG using Scalar vpss
Hi @deepg799 ,
Yes it can.
In the example application, just modify the use case for the scaler only:
From
vpssVideo useCase[TOPOLOGY_COUNT][USECASE_COUNT] =
//scaler only
{{{1280, 720, XVIDC_CSF_YCRCB_420, XTPG_BKGND_COLOR_BARS, FALSE,
1920, 1080, XVIDC_CSF_YCRCB_444 },
{1280, 720, XVIDC_CSF_YCRCB_422, XTPG_BKGND_COLOR_BARS, FALSE,
720, 480, XVIDC_CSF_YCRCB_420 }},
to
//scaler only
{{{1280, 720, XVIDC_CSF_YCRCB_422, XTPG_BKGND_COLOR_BARS, FALSE,
1920, 1080, XVIDC_CSF_RGB},
720, 480, XVIDC_CSF_RGB}},
//full fledged
Florent
Hi @deepg799 ,
If you are using the scaler only mode you need to make sure "Enable Color Space conversion" is enable in the IP configration.
Then if the option RGB | YUV4:4:4 | YUV4:2:2 | YUV4:2:0 you should be able to do any to any format conversion. Only configure the streams properly uisng the APIs.
Florent
@florentw It could be helpful for me if you share some sample code to configure color conversation APIs. I tried with below code but It is not working for me.
XVprocSs_Config* vprocss_config;
vprocss_config = XVprocSs_LookupConfig(XPAR_V_PROC_SS_0_DEVICE_ID);
if(vprocss_config == NULL){
xil_printf("ERROR:: VProcess Lookup failed\r\n");
return(XST_FAILURE);
XVprocSs_LogReset(&vprocss);
memset(&vprocss, 0, sizeof(XVprocSs)); // Init. all structure variable (vprocss) to ZERO.
status = XVprocSs_CfgInitialize(&vprocss, vprocss_config, vprocss_config->BaseAddress); // Init. vpross using vpross_config.
if(status != XST_SUCCESS){
xil_printf("ERROR:: VProcess Initialization failed\r\n");
if (rx_mode == 0) {
resolution = 4; //6 -1080p, 4-720p
else if (rx_mode == 2){
resolution = 6;
FRAME_HORIZONTAL_HSIZE = (u32) resolutions[resolution][5]; // rx_mode
FRAME_VERTICAL_LEN = (u32) resolutions[resolution][0];
xil_printf("Resolution: %dx%d\n\r",FRAME_HORIZONTAL_HSIZE,FRAME_VERTICAL_LEN); //1920x1080
thisCase.width_in = FRAME_HORIZONTAL_HSIZE;
thisCase.height_in = FRAME_VERTICAL_LEN;
thisCase.Cformat_in = XVIDC_CSF_YCRCB_422;
thisCase.IsInterlaced = FALSE;
thisCase.width_out = 1280;
thisCase.height_out =720;
thisCase.Cformat_out = XVIDC_CSF_RGB;
//Stream In
XSys_SetStreamParam(&vprocss, XSYS_VPSS_STREAM_IN, thisCase.width_in, thisCase.height_in,
thisCase.Cformat_in, thisCase.IsInterlaced);
//Stream Out
XSys_SetStreamParam(&vprocss, XSYS_VPSS_STREAM_OUT, thisCase.width_out, thisCase.height_out,
thisCase.Cformat_out, thisCase.IsInterlaced);
//Query video processing subsystem configuration
status = XVprocSs_SetSubsystemConfig(&vprocss);
XVprocSs_ReportSubsystemConfig(&vprocss);
Hi @deepg799 ,
Refer to the example application. It contains example.
The use cases for the scaler only is doing YUV420 > YUV444.
Florent
@florentw I want to convert from YUV4.2.2 to RGB, could Scalar will do it?
Hi @deepg799 ,
Yes it can.
From
//scaler only
to
//scaler only
//full fledged
Florent
@florentw Thanx for quick replay,
Ok, I will try. & let you know for further clarification.
