ZC706 Evaluation Board HDMI Example Design for Test pattern Generator in Vivado 2018.1 or 2019.1
HI,
I went through the Video Series Tutorial, Video series has example's for demostration of ZC702 for HDMI based Test Pattern Generator.
I am having ZC706 Board, Since the mode of operation of HDMI is changed from YcbCr 4:2:2 to Ycbcr 4:4:4. Since i am new to video processing. Please help.
Rajesh khanna
Tags (2)
Re: ZC706 Evaluation Board HDMI Example Design for Test pattern Generator in Vivado 2018.1 or 2019.1
We are able to resolve the issue in ZC706, problem is we need to use clock as 148.5 MHZ for 1920 X 1080 @ 60 Hz Resolution.
Rajesh khanna
Hello @rajeshkhanna
I believe you are mentioning design provided at https://forums.xilinx.com/t5/Video/Video-Series-19-Using-the-On-Board-HDMI-on-ZC702-Vivado-design/td-p/914989 . Please confirm.
I will reproduce this issue and let you know details.
Bhushan
Yes you are right we tried with the same design modified the ucf and settings corresponding to ZC706 but the design is not working.
Rajesh khanna
Hello @rajeshkhanna
There is limitation with ZC702 HDMI Codec innterface. Only 16-bit of Video Data lanes are connected for ADV7511 IC. So, ADV7511 supports 1080P 60Hz, YCbCr 4:2:2 encoding via 16-bit input data mapping on ZC702 board.
While YUV4:4:4 data type requires 24 bit Video data lines.
Bhushan
HI Bhusan,
Thanks for you reply.
The codec you are showing corresponding to ZC702. I having ZC706 the codec shown as per user guide is as follows. I am able to generate the bit file and able to detect the monitor. i am not able to send video to display. display resolution is 1920 x 1080 - 60 Hz.
Rajesh khanna
