ZCU102 HDMI ExDes 2018.1
What is the default streaming video format and memory video format used in this HDMI example pass through design?
http://www.wiki.xilinx.com/HDMI+FrameBuffer+Example+Design+2018.1
Vinay
Re: ZCU102 HDMI ExDes 2018.1
Hi @vinay_shenoy,
The design should also work with YCrCb 422 and 444
Hi @vinay_shenoy,
From my understanding it will take the max resolution from the EDID.
HI @vinay_shenoy,
Is the answer provided enough for you on this topic? If yes, could you kindly mark the reply as accepted solution. It no, please let me know what you could need fro this.
Hi @florentw,
I found that it works in RGB format throughout. How will the design behave with other video format ie, YUV 4:2:2 / YUV 4:4:4 ?
Vinay
Hi @vinay_shenoy,
Okay. Thanks
