Visitor swig
ZCU104 Audio
I have got to process audio input for use by voice recognition on ZCU104 Eval kit. Found no trace how to do it. Any suggestions?
Re: ZCU104 Audio
Yes correct
Re: ZCU104 Audio
Hi @swig,
You will need to start by inputting the audio data in the PL. Then once you know how to do that you can focus on your processing.
Visitor swig
Re: ZCU104 Audio
Hi Florent,
I am happy to hear there is a way forward. However, explain the PL abbreviation please.
Libor
Re: ZCU104 Audio
HI @swig,
PL means Programmable Logic. This is the "FPGA" part of the ZynqUS+ device
Visitor swig
Re: ZCU104 Audio
I see, thanks. Can you refer me to existing documentation to make it work?
Another question is about the hardware. For example, for ZCU102 you can plug in XA3 audio module, using SYSMON header. How about ZCU104, there is no such header for XA3. What options do I have in order to feed audio data from microphone to the board?
Thank you, Libor
Re: ZCU104 Audio
Hi @swig,
You should be able to use something like this:
https://store.digilentinc.com/pmod-i2s2-stereo-audio-input-and-output/
Visitor swig
Re: ZCU104 Audio
Just to make sure I am on the right track.
- Pmod I2S2 fits into ZCU104 PMOD GPIO Connectors (headers J55).
- Apply implementation of Inter-IC-Sound (I2S) interface for sound PCM, like it is suggested below:
https://www.xilinx.com/products/intellectual-property/audio-i2s.html
Please confirm I've got it. Thanks a lot for guidance.
Re: ZCU104 Audio
Yes correct
Visitor swig
Re: ZCU104 Audio
thank you very for the help. I am rolling up my sleeves and getting down to work.
