Observer bhdschmidt
ZCU104 with Optical Flow Demo (Revision), does it work?
I recently received my ZCU104 and tried to get the Revision Demo up and running (in particular, the optical flow demo, see http://www.wiki.xilinx.com/reVISION+Getting+Started+Guide+2017.4+rev2). Unfortunately, I wasn't successful.
My hardware setup is the ZCU104 with the e-con webcam as video source and a HDMI monitor as sink.
I tried execute every command as described on the wiki page. In the end, I executed the following line:
gst-launch-1.0 v4l2src device=/dev/video4 io-mode=dmabuf ! "video/x-raw, width=1920, height=1080, format=UYVY" ! sdxopticalflow filter-mode=1 ! queue ! kmssink driver-name=xilinx_drm_mixer plane-id=26 sync=false
Then I got stucked with that output:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data flow error.
Additional debug info:
../../../../gstreamer-1.8.3/libs/gst/base/gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming task paused, reason not-negotiated (-4)
Execution ended after 0:00:00.031051191
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
The monitor shows a "blue screen", but there are some reactions here and then.
If anyone can help, I really would be very grateful.
Bernhard
Visitor pauldirac
Re: ZCU104 with Optical Flow Demo (Revision), does it work?
same with me. Exact same error:
Visitor pauldirac
sdxopticalflow is the reason for the fault. Both modes (SW&HW) are broken.
if i try videoconvert instead of sdxopticalflow, it works.
soren, could U plz help us out ?
Visitor pauldirac
all right, it works (kinda)
ssh into it.
1st shell:
video_cmd -d 1 -o 1920x1080-60Hz@AR24
ERROR: Query DV timings failed: Link has been severed
Ignore the error message. As you don't need to exit the command, no reconfiguration of the sink takes place.
2nd shell:
video_cmd -s 1 -i 1920x1080@UYVY -X
gst-launch-1.0 v4l2src device=/dev/video4 io-mode=dmabuf ! "video/x-raw, width=1920, height=1080, format=UYVY" ! sdxopticalflow filter-mode=1 ! queue ! kmssink driver-name=xilinx_drm_mixer plane-id=28 sync=false
this works in hw mode only. The manual states that sw mode is not available. So we are all set.
Observer bhdschmidt
Hi paudirac,
sorry for my late response. Unfortunately, I wasn't able to run the demo with commands you suggested. Instead I got this error message:
(gst-plugin-scanner:2798): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-1.0/libgstsdxbase                                              .so': /usr/lib/gstreamer-1.0/libgstsdxbase.so: undefined symbol: gst_sdx_allocator_new
(gst-plugin-scanner:2798): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-1.0/libgstomx.so'                                              : /usr/lib/gstreamer-1.0/libgstomx.so: undefined symbol: gst_omx_h265_enc_get_type
../../../../gstreamer-1.8.3/libs/gst/base/gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline0/G                                              stV4l2Src:v4l2src0:
Execution ended after 0:00:00.019741217
Does that make sense for your? I completely lost :(
Bernhard
Have you solved your problem, I have this error too.
HDMI as output port.
HI junning.wu@ia.ac.cn,
There errors happen if the linux does not find the HDMI monitor
Florent
Visitor pauldirac
hi bhd, may be You have already tried the new version (with/for SDx 2018.2).
As junning.wu pointed out in https://forums.xilinx.com/t5/Video/ZCU104-OpticalFlow-Could-not-open-DRM-module-xilinx-drm-mixer/m-p/871416/highlight/false#M20870
one has to specify the bus id explicitly, together with plane-id 31:
video_cmd -d 1 -s 1 -i 1920x1080@UYVY -X
gst-launch-1.0 v4l2src device=/dev/video4 io-mode=dmabuf ! "video/x-raw, width=1920, height=1080, format=UYVY" ! sdxopticalflow filter-mode=1 ! queue ! kmssink driver-name=xilinx_drm_mixer bus-id=b00c0000.v_mix plane-id=31 sync=false
(my config: SeeCam & HDMI Monitor)
I did compile it all by myself , coz I run in troubles with the precompiled SD folder content. (Donno why anymore though...)
Hope this hlps...
Hi all,
Does anybody really had this working?
From the prebuilt binaries:
Step 1
cp lib/libopticalflow.so /usr/lib
cp gstreamer-1.0/libgstsdxopticalflow.so /usr/lib/gstreamer-1.0
cp lib/libgstsdxbase.so /usr/lib/gstreamer-1.0
cp lib/libgstsdxallocator.so /usr/lib/gstreamer-1.0
Step 2 (set see3cam video)
Step 3 (display port output)
video_cmd -d 0 -o 1920x1080@UYVY&
Step 4 (launch pipe)
gst-launch-1.0 v4l2src device=/dev/video4 io-mode=dmabuf ! "video/x-raw, width=1920, height=1080, format=YUY2" ! sdxopticalflow filter-mode=1 ! queue ! kmssink bus-id=fd4a0000.zynqmp-display plane-id=34 sync=false fullscreen-overlay=true
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
../../../../gstreamer-1.12.2/libs/gst/base/gstbasesrc.c(2939): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.121183398
It doesn't matter what config I try, it is always the same...
/* Don't forget to give kudos and/or accept as a solution */
Visitor lucc1
Trying to find this: "video_cmd" from the zcu104-rv-ss-2018-3 image.
Is this something that get installed separately.
How can I get this "video_cmd" command on the board?
Luc
