ZCU106: MIPI RX example
I would like to have MIPI RX example for ZCU106 as in the vivado it just displays fro ZCU102 and because of license issue, it fails to load.
I am lookign for example for with bare metal platform (without operating system).
It will be a great help if someone can point me to this example for ZCU106.
Thank you in advance
Best regards
Tags (2)
Re: ZCU106: MIPI RX example
HI @msh,
It was discussed in this topic:
https://forums.xilinx.com/t5/Video/MIPI-interface-Technology-Development-issues-green-display-on/td-p/874829
This is because there is no White Balance block implemented. Xilinx does not have one. You might want to do your own or look at our partners.
Florent
Hello @msh
For MIPI CSI-2 RX, we only have example design for US+ that target ZCU102.
Our development team has a plan to add an Example design targeting 7-series board for future Vivado release.
But I do not think we have a milestone for Exampe design targeting ZCU106 board.
If you are trying to use ZCU106 board, then I suggest you to generate the example design using ZCU102.
You will need to modify the pin-assignment though.
If you have license issue, you can try to use evaluation license for a specific IP you do not have.
Thanks & regards
Leo
Hi @msh,
You should be able to use the VCU TRD as reference. It has a MIPI RX on ZCU106
Florent
Hi @msh
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" buton below the reply)
Thanks and Regards,
Florent
Yes, it works with changing only PIN configuration.
I would like to know why the video output is green in color?
Best regards
HI @msh,
Florent
There is another question
I connect a monitor on HDMI output, which supports 4K at 60Hz. But when changing the resolution to 4k 60Hz in the program it throws an error that "HDMI is not configured for 4k 60 Hz resolution". on the other hand 4k 30Hz works.
May I know what could be a problem.
Best regards
HI @msh,
I am not sure about the issue here but it might just be that the design was made for 4k30 as this is the maximum the MPSoC DP can do (so HDMI could have been aligned)
Florent
The TRD from xilinx can support 4k 60 hz
http://www.wiki.xilinx.com/Zynq+UltraScale%EF%BC%8B+MPSoC+VCU+TRD+2018.2+-+Design+Module+4\
I am not sure what difference can be there between them.
Hi @msh,
Are you using command line? The GUI is not supported for 4k60
Florent
I am using example project for mipi_csi2_rx_subsystem_0 (generated from vivado). This example works with bare metal but only till 4k 30hz whereas there is an option in the software to set to 4k 60hz. When I set to 4k 60hz it shows me an error that HDMI cannot be configured for this resolution.
I was comparing this project with TRD. where the HDMI implementation work for 4k 60hz. Hence I would like to know what could be the difference between them. So that I can make changes and run this project for 4k 60hz.
Best regards
Hi @msh,
I believe this is the way they have been designed. You might want to check all the IPs to make sure they were configured for 4K30.
You can always try to build the TRD HW design and compare both
Florent
Hello
I am able to configure the example for 4k 60 Hz. Please see the attachment doc for it
Still there is a little problem,
I need to set the resolution to 4k 30Hz and then go into menu option to set to 4k 60Hz. This  make it work
Any suggestion how to solve it.
Best regards
