Visitor lh123lh
ZYNQ + Parallel interface cmos camera OV5640 Linux driver
Hello everyone,
I want to use parallel interface of the ov5640 camera in linux, but i can not find any device driver in the xlnx-linux(kernel version 4.14.0),someone can help me?
Visitor lh123lh
Re: ZYNQ + Parallel interface cmos camera OV5640 Linux driver
Hi,watari
Thanks for your reply,I have been solved this problem successfully.By the way ,"Parallel Interface" is the "DVP Interface".
Hi @lh123lh,
I am not sure how much work is involved to have the camera working. Are you using any IPs to connect to your camera. This is the drivers for this IP that you should be looking.
Florent
Scholar watari
Hi @lh123lh
I'm not familiar with OV5640 Linux driver.
However I mention to you.
What do you mean "Parallel Interface" ?
Is the interface "Parallel" between OV5640 to FPGA for video signal ?
(It seems that the interface is MIPI CSI from linux-xlnx/drivers/media/i2c/ov5640.c)
Is the interface "Parallel" between OV5640 to FPGA for host interface ?
(It seems that the interface is I2C from linux-xlnx/drivers/media/i2c/ov5640.c)
If you only used OV5740 in linux and didn't find any source codes in linux-xlnx/drivers/media/i2c/ov5640.c, I guess you can do back port OV5640 driver's from latest to your version.
Would you share mode details ?
Best regards,
Visitor lh123lh
Hi,watari
Visitor lh123lh
Hi,florentw
Thanks for your reply.
Hi @lh123lh,
Thank you for sharing.
As this is now solved for you, could you kindly mark the topic as closed by marking your previous reply as accepted solution?
Thanks and Regards,
Florent
