Zybo AXI VDMA doesn´t work
I want to use VGA on my Zybo. So I decide to use the AXI VDMA and the Video Timing Generator. My block diagram looks like this.VGA.png
And my code is this
#include "xaxivdma.h"
#include "xparameters.h"
XAxiVdma* InstancePtr;
int main()
	xil_printf("Configure VDMA...\n\r");
	XAxiVdma_Config *Config;
	Config = XAxiVdma_LookupConfig(XPAR_AXI_VDMA_0_DEVICE_ID);
	if (!Config) {
		xil_printf("No video DMA found for ID %d\r\n", XPAR_AXI_VDMA_0_DEVICE_ID);
		return XST_FAILURE;
	/* Initialize DMA engine */
	u32 status = XAxiVdma_CfgInitialize(InstancePtr, Config, Config->BaseAddress);
	if (status != XST_SUCCESS)
		xil_printf("Configuration Initialization failed, status: 0x%X\r\n", status);
		return status;
	xil_printf("Start...\n\r");
	while(1)
	return 0;
But this program stucks at this line
So what´s wrong with this?
Re: Zybo AXI VDMA doesn´t work
I found the error. The XAxiVdma-Pointer is initialized with NULL, so the Assert in the VDMA-Driver got triggered. I changed it from
XAxiVdma* Pointer;
XAxiVdma_CfgInitialize(Pointer, Config, Config->BaseAddress);
to
XAxiVdma Instance;
XAxiVdma_CfgInitialize(&Instance, Config, Config->BaseAddress);
It works now...
Next step is a VGA image :)
Mentor watari
Mentor
Hi @kampi
I suggest you to make sure input floating, ex. Intterrupt and Video Timing modules, and the polarity of Reset.
Would you try it ?
Hi @kampi ,
I would agree with @watari . The first thing to check is looking at the reset. The IP might be held in reset.
I would also try do debug step by step your application and see exactly when it is failing inside the function XAxiVdma_CfgInitialize.
Also, you might want to check my video series 24 for an example using the VDMA. I am not using the VDMA driver's APIs but you can refer the design as an example.
thank you for your answer. I will test it :)
XAxiVdma* Pointer;
to
XAxiVdma Instance;
It works now...
Hi @kampi ,
Good to know that you were able to solve your issue.
Could you kindly mark your previous reply as accepted solution (click on the accepet as solution button while logged in).
Kind Regards,
