Zybo z7 20 HDMI
hi,
I have Zybo z7-20 board. I want to run ubuntu and want to see through HDMI. I have tried the procees given in this link "https://forums.xilinx.com/t5/Video/Zybo-HDMI-output-Wrong-colors-rendering-on-Linux/td-p/950612" but failed.
Also tried to see the output using the github example but failed. Board has alredy demo build and it shows the color screen when I connect the HDMI tx to LCD.
Can anyone help me to bring up the board from the base and help me up the board using ubuntu to see through HDMI.
Gaurav
Re: Zybo z7 20 HDMI
HI @gaurav.shukla
I do not think the demo you have is running under linux, right?
From what I can find, the example available is running into baremetal. You need to start with that. Then you can move to petalinux to start running under linux and finally run ubuntu.
I am not aware of an out of the box solution so you will probably need to do some work on it.
Florent
Re: Zybo z7 20 HDMI
HI @gaurav.shukla
Florent
Re: Zybo z7 20 HDMI
In this Digilent forum message Qt on Zyboz7-20 via LX FrameBuffer to HDMI monitor i got Qt GUI via frame buffer on LX. It is also possible to integrate frame buffer driver in LX Xorg infrastucture Using Xorg (i didn't try it, Qt is ok for me).
Re: Zybo z7 20 HDMI
Hi @gaurav.shukla,
Are you still running into an issue?
If your question is answered or your issue is solved, please kindly mark the response which helped find a solution (click on "Accept as solution" button below the reply)
If this is not solved/answered, please reply to the thread giving more information on your current status.
Thanks and Regards,
Xilinx Video Design Hub
