Visitor hisuer
Zynq UltraScale+ MPSoC VCU TRD 2018.3-VCU SDI TX 422 10bit Support
I am using a Zynq Ultrascale+ MPSoC ZCU106 board,based on “\rdf0428-zcu106-vcu-trd-2018-3\images\vcu_sditx”;I want to do test decode HEVC 422 10bit and output 10bit stream.
We use “gst-launch-1.0 -v udpsrc uri="udp://192.165.54.218:12340" ! tsdemux ! queue ! h265parse ! omxh265dec ! kmssink bus-id="a0070000.v_mix"”, When Decode 420 8bit stream it work fine.
When stream changed to  422 10bit, omxdec report negotion errror.
Re: Zynq UltraScale+ MPSoC VCU TRD 2018.3-VCU SDI TX 422 10bit Support
HI @hisuer
I think only NV12 (i.e. 420 8bit) is supported for SDI in the VCU TRD 2018.3. This is why it is not working for you.
the VCU TRD 2019.1 seems to support XV20 for SDI TX (link) which is YUV422 10 bit. Yoiu might want to try with this version
Florent
Visitor hisuer
We test on 2019.1, xmodtest have XV20 support.So 2018.3 cann't support 422 10bit out?
Hi @hisuer
I believe both the design and the driver in 2018.3 were not done for 10-bit. Please use 2019.1 for XV20.
Florent
Visitor hisuer
Thanks I will move to 2019.1
Hi @hisuer
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
