Participant brianvg
Zynq+UltraScale+MPSoC+VCU+TRD+2018.3
Doing some work to port portions of the subject line TRD to a new hardware platform, and I noticed that some of the frame buffer DMA engines use 32 bit addressing and some use 64 bit addressing. All of the video data path elements only interact with the DDR_LOW regions of the memory, which should only require the first 32 bits of the address map. Is this on purpose, or an oversight? I would think that removing the upper order addressing bits could/should save some resources in the mapped design.
Brian
Re: Zynq+UltraScale+MPSoC+VCU+TRD+2018.3
Hello @brianvg
Do you have any updates on this? Were you able to find an answers?
Thanks and Regards,
Hi @brianvg ,
Could you clarify which design of the TRD you are talking about? And also which frame buffer you saw configured for 32-bit addressing?
I checked the full vcu trd design ands all the frame buffers are configured for 64 bit addressing
Hello @brianvg
Thanks and Regards,
Participant brianvg
Hi Florent,
Thanks for getting back to me on this.
I am sorry, I wrote the wrong name in the subject line. I should have said the "zcu106_HDMI_ref" design. I ran this design in windows and I guess that some of the parameters were not set correctly. I think you can mark this as solved.
Best Regards,
Brian
