Zynq UltraScale+ MPSoC - ZCU106 HDMI Example Design - not running on Vivado 2018.1
Hello, I would like to run the following example from Xilinx Wiki:
I followed the steps to open the project but I got an error because the specified part is not available on Vivado 2018.1 (xczu7ev-ffvc1156-2-i-es2, which seems to be an engineering sample part). I edited the board.xml, zcu106_hdmi_ref.tcl and zcu106_hdmi_ref_prod.tcl files to use another part (xczu7ev-ffvc1156-2-i, the same one without the -es2 suffix) and then I could open the project but some blocks and all connections between blocks are missing. I was wondering if this example is also available for the zcu106 evalkit with the current Zynq part on it. Otherwise I would like to know if it might work just editing some more files besides the one I listed. I am especially interested in the test pattern generator subsystem and its connections. The HDMI IN/OUT subsystems are fortunately included in the ZCU106 examples that are available on the the Xilinx site so I could test them, but I did not find any example where the pattern generator is also included.
Thanks a lot!
Tags (2)
Re: Zynq UltraScale+ MPSoC - ZCU106 HDMI Example Design - not running on Vivado 2018.1
Hi @javichu,
What is the silicon on your ZCU106? If it is a production silicon, there is not point for you to use a ES part for the vivado project.
You might want to use the VCU TRD as example design. It also uses HDMI and the design is similar.
Florent
Hello @javichu,
Try checking if you have selected ES parts while installing VIVADO.
Take help of following answer record:
https://www.xilinx.com/support/answers/60112.html
Try to refer the HDMI TX design available for ZCU106. This example design includes TPG for pattern generation.
Refer PG235  for more help.
https://www.xilinx.com/support/documentation/ip_documentation/v_hdmi_tx_ss/v3_1/pg235-v-hdmi-tx-ss.pdf
Thank you.
Hello @kvasantr,
thank you for your reply. I had already downloaded the ES but the problem is that there are no ES parts from the EV family. I can see some on the list from the XCZU9EG family for example, so I know I got some of the Ultrascale+ ES parts during installation. When I check for extra content I might have not installed yet I get to the following list, where all ES parts are checked:
Where could I find the missing ES part? Is it no longer available? Is there anything else I should install? Thank your for your help anyways.
Best Regards,
Javichu
Hi @javichu,
Florent
