Observer sigan
Zynq UltraScale+ | Video PHY Controller | GTH4 Tx Utilization
so I have a couple of questions regarding the GTH transceivers utilization in the Zynq XCZU6 device. Since we are using the FFV900 package of the Zynq XCZU6 there is a total of four GTH4 Quads according to https://www.xilinx.com/support/documentation/user_guides/ug1075-zynq-ultrascale-pkg-pinout.pdf, page 51. The plan is that the Zynq PL shall instantiate one HDMI 2.1 IP core Rx only (but for the time being it is one HDMI 2.0/1.4, since the HDMI 2.1 core is not available) and DisplayPort 1.4 Rx only. Both of these cores use the Video PHY Controller that internally wrap one GTH4 quad each. On our board we want to make use of all the 16 GTH4 Tx channels towards another board and the eight GTH4 Rx channels that are not used in the HDMI and DisplayPort Video PHY Controllers.
How can we use the GTH4 Tx channels that are internally wrapped in the Video PHY Controllers for HDMI and DisplayPort?
I am guessing we need to modify the Video PHY Controller. And by doing so, do we still get support from Xilinx if things do not work or any other issues?
The tentative plan is as follows:
Use the GTH4 Rx channels in Quad 229 for DisplayPort 1.4. 270 MHz -> MGTREFCLK0 pins.
Use the GTH4 Rx channels in Quad 230 for HDMI 2.0/1.4. HDMI link clk -> MGTREFCLK0 pins and DRU ref clock -> MGTREFCLK1 pins.
Drive 156.25MHz clock on MGTREFCLK0 pins on Quad 228. This clock will then be used by all Tx channels in Quad 228, 229 and 230. And
also the Rx channels in Quad 228.
Since it is not possible (I believe) to drive Quad 128 with the reference clock from Quad 228, since its placement is neither north/south of Quad 228. The Tx and Rx channels in Quad 228 will be driven its own reference clock at 156.25MHz.
Video PHY Controller:
The Video PHY Controller for DisplayPort only needs one reference clock at 270 MHz, correct? Or does it need a separate Link clock dependent on the GT_Datawidth parameter on page 51, https://www.xilinx.com/support/documentation/ip_documentation/vid_phy_controller/v2_2/pg230-vid-phy-controller.pdf.
Re: Zynq UltraScale+ | Video PHY Controller | GTH4 Tx Utilization
Hi @sigan
Yes, to be able to use different protocols in a single quad you will need to edit the Video PHY. But, this is physically possible.
In term of support, if you modify the Video Phy, this is not officially supported by Xilinx Technical Support (thus through the Service Portal).
With that said, I talked with your FAE and he should be able to support you in modifying the Video Phy. He should contact you but I encourage you to contact him first (in case he forgets).
About the reference clock for the Displayport 1.4, yes you only need a single 270MHz for the GT. The link clock is derivated from the rxoutclock.
Florent
Hi @sigan
Florent
Observer sigan
Hi @florentw , thank you a lot for your reply, really appreciate it! I will contact our FAE.
