Zynq Ultrascale+ MPSoC VCU TRD
I am using a Zynq Ultrascale+ MPSoC ZCU104 board. I cant find a trd or example design for this board.
Would ZCU106 board trd be helpful? Or are there some other helpful ways?
Re: Zynq Ultrascale+ MPSoC VCU TRD
Hi @yildizbilgin ,
TRD for ZCU104 is not available.
---No.
---You can use BSP of ZCU104 as an alternative.
Hope this helps.
Deepak D N
Please Kudo or Accept as a Solution, if it helps.
Hi @yildizbilgin ,
---No.
Hope this helps.
Deepak D N
Is BSP of ZCU104 for linux? Because I am using Windows.
You can open .bsd file via 7z zip manager. Inside the .bsp file, there is a vivado project inside the hardware folder which includes vcu implemented zcu104 project.
Hey, I sent you a private message. Can you take a look?
