a question a bout Convolution Encoder and Decoder
I have a data get through the Convolution Encoder.
Now i want to decode the convolutional to check the Encoder works or not. So what block should i use?
Is the Virtebi Decoder or anything else?
Thank you very much!!!
Re: a question a bout Convolution Encoder and Decoder
Yes, the viterbi decoder works with convolutional codes. Have a look at the sysgen demos for some examples.
www.xilinx.com
www.xilinx.com
thank you so much bwiec.
