aurora 8b 10b connect vdma question
i use aurora 8b ip ,i config this ip rx-simplex-timer mode, rx data is right, i connect user_m_axi_rx interface with axis data fifo(async), than i connect fifo m_axis interface to vdma s2mm interface, i use ila for debug s2mm, but the vdma can't move data to ddr,i don't kown why.
Re: aurora 8b 10b connect vdma question
Hi @mountainfpga
How did you configure the VDMA?
Did you check  the status register?
Does the data from Aurora include the video signals (tuser for SOF and tlast for EOL)?
I have wrote some examples using the VDMA as part of my video series. You might want to have a look to understand how the VDMA is working. Maybe start with a TPG as a source and then move the VDMA
Video Series 24: Using the AXI VDMA in Triple Buffer Mode
Video Series 25: Debugging issues on the AXI VDMA IP
Video Series 26: Examples of advanced uses of the AXI VDMA IP
because of my vdma config fsync option,I use aurora framming,which has no tuser,so vdma write is not work, thanks
Hi @mountainfpga,
I wanted to confirm that without tuser VDMA will not work as it uses tuser as control logic.
Do you have other questions on this topic or is it clear for you?
Sam
Xilinx Video Design Hub
I have solved this problem.
Hi @mountainfpga
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply).
Otherwise, would you be able to share your solution for other members?
Aoife
ok,no problem, how to share it?
Hi @mountainfpga
Can you describe what you did to solve this issue so other members of the community can replicate your solution if they need to?
Aoife
