Observer donghoang22017
bandwidth of xlnxscale plugin
I am using ZCU104 board. In the design in FPGA I use VideoFrameBufferRead, VideoFrameBufferWrite and VideoProcessingSubSystem ip cores to convert YUV format to BGR. Those IP are controlled by gstreamer plugin xlnxscale.
The problems is when the output of xlnxscale is large (for example: input frame is 1920x1080 YUV, output frame is also 1920x1080 BGR), the fps is quite low (about 20fps).
Can someone provide me the bandwidth of VideoProcessingSubSystem or xlnxscale plugin ???
Thanks in advances !!!
Re: bandwidth of xlnxscale plugin
Hi @donghoang22017
Can you add a second VPSS configured as color space convertor to do the color space conversion?
So basically change your pipe from
Video Frame Buffer Read (YUV) -> Video Processing Subsystem (Scaler) ->  Video Frame Buffer Write (BGR8)
to
Video Frame Buffer Read (YUV) -> Video Processing Subsystem (CSC) -> Video Processing Subsystem (Scaler) ->  Video Frame Buffer Write (BGR8)
This is how it is done in our examples as the VCU TRD. Else it might be that the conversion is handled by the OS.
Mentor watari
Mentor
Hi @donghoang22017
Would you share your gstreamer pipeple ?
"WIDTH=1920
HEIGHT=1080
WOFF=0
HOFF=0
gst-launch-1.0 filesrc location=video/CIST.mp4 ! qtdemux name=demux demux.video_0 ! h264parse ! omxh264dec internal-entropy-buffers=3 ! xlnxscale need-tdm=true ! \
video/x-raw, width=$WIDTH, height=$HEIGHT, format=BGR ! \
fpsdisplaysink video-sink="kmssink plane-id=29 bus-id="a0070000.v_mix" render-rectangle=\"<$WOFF,$HOFF,$WIDTH,$HEIGHT>\"" text-overlay=true sync=false "
Here is my gstreamer pipeline.
Mentor watari
Mentor
Hi @donghoang22017
Would you share your clock setting on xlnxscale IP ?
It seems clock frequency issue.
Hi @watari
In Block Design of FPGA, my xlnxscale IP is using 330MHz clock. I am using the following IPs: Video Frame Buffer Read (YUV), Video Processing Subsystem (Scaler), Video Frame Buffer Write (BGR8).
Best Regards,
Mentor watari
Mentor
Hi @donghoang22017
How about bus width ?
In this case, you need to consider overhead by CPU.
Hi @donghoang22017
to
Hi florentw,
I tried as your suggestions and it improved the performance. Thanks in advances ! :D
