Visitor murali@1996
camera link to DVI conversion
Hiiiiiii,
 The data conversion from camera link to DVI,
how can i use the HSYNC, VSYNC, BLANK in DVI interface from LVAL,DVAL,FVAL in camera link interafce. is both are same...?
else, any other logic is required to get sync signals of DVI from camaera link...?
Scholar watari
Re: camera link to DVI conversion
Hi murali@1996
Here are the meaning of each signals.
HSYNC : Horizontal synchronous signal
VSYNC : Vertical synchronous ginal
BLANK : Blanking singnal
LVAL : Line valid
DVAL : Data valid
FVAL : Frame valid
As you know, you need other logic to generate suitable signal for DVI from camera link.
Visitor murali@1996
Thank @watari,
is
LVAL - HSYNC,
FVAL - VSYNC
DVAL - BLANK
are the same appart from the other parameters???
Scholar watari
Hi murali@1996
What do you mean ? Do you think that it needs an inverter ?
If yes, it's correct.
If no, the meaning of my previous mentioned is that it is different between each pair signals.
Would you consider it ?
