camera link to DVI conversion
Hiiiiiii,
 The data conversion from camera link to DVI,
how can i use the HSYNC, VSYNC, BLANK in DVI interface from LVAL,DVAL,FVAL in camera link interafce. is both are same...?
else, any other logic is required to get sync signals of DVI from camaera link...?
Tags (2)
Re: camera link to DVI conversion
Hiiiii @watari and @florentw ,
Sorry for the delay, I was mapped The camera link signals with DVI as follows,
HSYNC <= Line Valid
VSYNC <= Frame Valid
DE         <= Data valid
but due to the timing diffrence between the camera interface and DVI, I took the valid data and stored with the DVAL signal from camera link, an dispalyed the same data into DVI by DE signal as a read.
now whatever data captured in camera is displayed by DVI interface.
Thanks for your support...!
Scholar watari
Hi murali@1996
Here are the meaning of each signals.
HSYNC : Horizontal synchronous signal
VSYNC : Vertical synchronous ginal
BLANK : Blanking singnal
LVAL : Line valid
DVAL : Data valid
FVAL : Frame valid
As you know, you need other logic to generate suitable signal for DVI from camera link.
Best regards,
Thank @watari,
is
LVAL - HSYNC,
FVAL - VSYNC
DVAL - BLANK
are the same appart from the other parameters???
Scholar watari
Hi murali@1996
What do you mean ? Do you think that it needs an inverter ?
If yes, it's correct.
If no, the meaning of my previous mentioned is that it is different between each pair signals.
Would you consider it ?
Best regards,
Hi murali@1996,
Do you have any updates on this? Was @watari's reply enough for you?
Florent
HSYNC <= Line Valid
DE         <= Data valid
Hi murali@1996,
Thank you for sharing your solution. As this is solved, could you kindly close the topic by marking your last reply as accepted solution (click on accept as solution button while logged in).
You might also give kudos to @watari to thank him for his help by using the "like" button.
Best Regards,
Florent
