color format of HDMI Rx IP
HEllo,
how to find color format of HDMI Rx IP. to send the type of color format in AXI stream.
Tags (2)
Scholar watari
Re: color format of HDMI Rx IP
Hi @daram123
Would you use InfoFrames which is called "AVI (Auxiliary Video Information)" ?
https://github.com/Xilinx/embeddedsw/blob/master/XilinxProcessorIPLib/drivers/v_hdmi_common/src/xv_hdmic.c
Best regards,
@watariAuxiliary Video Information Info Frame is in AXI Lite, how to bring it the AXI stream..??
regards,
Prasanna Daram
Scholar watari
Hi @daram123
Do you mean that your design automatically use infoframe without microblaze ?
Best regards,
@watariFrom the MicroBlaze the registers data for video format have to  travel AXIStream, for dataType Selection,
regards,
Prasanna Daram
@daram123
It depends on the HDMI Source that drives to HDMI RX IP, as long as EDID in HDMI Rx supports it, the color format can be detected.  If you follow chapter 5 of PG236, run example design, type "i"menu, it tells you the color format and all other color information for the incoming stream.
