Observer parithyila
display port and vedio phy controller
I am working with dispaly port and video phy contrller, i have attached the integrated block diagram pls have a look on it.
when i am reading the PLL Lock Status (PLS) Register (0x0018) of vedio phy controller all the values in the register are 0, from that i understood that my qpll is not locked.
below is the sequence of writing data to vedio phy controller
1.write PLL Reset Register (PR) (0x0014)   seting all the bits 1
2.write Reference Clock Selection (RCS) Register (0x0010)  =C000031
3. write PLL Reset Register (PR) (0x0014)   seting all the bits 1
4.reading PLL Lock Status (PLS) Register (0x0018)
if i read the PHY Configuration Status from sp 0x280 i am geting the value 6c is this correct.
I am using 135 Mhz clock for all my design, why my qpll status is alway 0 ,
i am using vivado 2016.4
pls verify the below attached block diagrm . let me know  why  qpll status is alway 0
Re: display port and vedio phy controller
As Watari mentioned jitter needs to be considered for this clock as it is a GT clock. I do not suggest using an internal clock.
GT clock requirements are listed in each of the DC and AC Switching Characteristics guides.
As an example here is the table for the Kintex Ultrascale DS893. Use the Phase Noise Mask to select a clock chip. Vendors usually have phase noise listed in their documentation.
2019-08-30 08_36_53-Xilinx Documentation Navigator 2018.3 -  https___www.xilinx.com_support_document.png
Xilinx Video Design Hub
Hi @parithyila,
Directly programming the registers is not supported, please use the drivers as the process to initializing can be complicated and this already written and tested for you by our drivers. Is there a reason that you are using 2016.4? Check the ARs below for all of the improvements and bug fixes since 2016.4. Also there is an example design available starting in 2017.3.
RX:
http://www.xilinx.com/support/answers/65447.htm
TX:
http://www.xilinx.com/support/answers/59384.htm
PHY:
http://www.xilinx.com/support/answers/57842.htm
My suggestion is to upgrade to Vivado 2017.3 or newer and use the example design as a reference and as a tool to test your hardware (if on custom hardware).
Observer parithyila
Hi samk,
thanks for replying,
I am not clear about driver you have mentioned . are your saying about  microblaze ?
Right now i am using Axi master as a driver  to drive the register values . Do i need to drive the value through microblaze?
regards
ilam
Hi @parithyila,
Yes, a processor is required for the Video PHY controller. Either an ARM (Zynq) or MicroBlaze.
Take a look at one of the example designs and I believe this will answer your questions.
Observer parithyila
Hi samk,
Thanks for your reply i will come back if there is any need
regads
ilam
Observer parithyila
Hi samk,
can we generate 135Mhz internally from FPGA   or we need to use external clock as a reference clock for viedo phy controller,
right now i am generating internally.
regards
ilam
Scholar watari
Hi @parithyila
You should consider input clock jitter for DP IP.
So, I suggest you to use external clock device which has low clock jitter as reference clock.
Best regards,
Hi @parithyila
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
