display port rx subsystem
i am doing Video Displayport 1.4 rx subsytem Example design. But by default it have zcu102 evalution board (xczu9eg-ffvb1156-2-e).But i want to change part number with xczu6eg-ffvc900-1-e. So i want to change constraints.where can i get constrains of xczu6eg-ffvc-900-1-e part. can anyone help me please.
Re: display port rx subsystem
Hello sy5809358@gmail.com  ,
The Zynq UltraScale+ MPSoC Package all Device Pinout Files are available in the below link,
https://www.xilinx.com/support/package-pinout-files/zynq-ultrascale-plus-pkgs.html
The part number XCZU6eg-ffvc900-1-e, pin out text file is addressed in the below link
https://www.xilinx.com/support/packagefiles/zuppackages/xczu6egffvc900pkg.txt
Kindly let me know, if you face any problem, while using the above links.
With Regards,
Ashok
DisplayPort1.4 RX example designs are created for VCU118, KC705 and ZCU102 boards only. If you want to port this example design to your custom Xilinx FPGA board, then you need to understand default example design pinout connections and then remap this connections according to your FPGA board.
Bhushan
i changed the pinouts according to xczu6eg-ffvb900-1-e. bu.t i got the errors in placement.see the below attachment.
Hi sy5809358@gmail.com
I hope the BUFG's are exceeded in the design with the FPGA what you had selected. Could You Please Confirm this.
With Regards,
Ashok.
May I know the status of this case, If your case was resolved with our inputs, please mark it as accepted solution.
With Regards,
Ashok
Scholar watari
I guess you might execute Vivado on Windows.
If yes, you are facing file path length issue (instance length issue) like you mentioned before.
So, I suggest you to reduce file path length or change OS from Windows to Linux or modify registory value by regedit and so on or change policy by policy editor.
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
