displayport tx subsystem
I am implementing display port tx subsystem on xczu9eg-ffvc900-1-e part.In this design utility buffer is used.in utility buffer i am using cbuf type is IBUFDSGTE.my doudt is how to give differential input to the utility buffer..is it required in displayport tx subsystem or is there alternative to give clock.please help me.
Re: displayport tx subsystem
Hello sy5809358@gmail.com
First of all I am not very clear with your requirement.
I believe you are talking about utility buffer used in DisplayPort1.4 TX example design mentioned in Chapter 6 of PG299 (v2.1) as follows:
Above snapshot is for DisplayPort1.4 TX example design based on ZCU102 board.
Clock constarints are mentioned in top_zcu102.xdc as follows:
MGTREFCLK0 pin connection on ZCU102 board:
MGTREFCLK1 pin connection on ZCU102 board:
You can check more details in UG1182 (v1.6) and ZCU102 Schematics for this connections.
Please check PG230 (v2.2) DisplayPort Clocking section for detailed understanding.
So, as you are using IBUFDSGTE you need to use differential clock only.
Please provide details of your board (Xilinx or custom board, clock sources available on your board etc..), DisplayPort IP version; if you have any further queries.
Bhushan
Bhushan
