dp v2.1 example design color format change
I am using DP Tx Subsystem v2.1 in KC705.
Refering to PG199,the RGB/YCbCr444/YCbCr422/Y-Only color formats are supported dynamicly.
So I creat an example design,replacing tpg with av_pat_gen mode,with RGB color formats tpg output.
Applicataion operating normally,and the monitor display correctly.
Then I set tpg color format to yuv422,but there are no format change option in application command list.
Applicataion operating normally,but the monitor display incorrectly.
Finally,I find the functions in xdp.h!
* u32 XDp_TxCfgSetRGB(XDp *InstancePtr, u8 Stream)
* u32 XDp_TxCfgSetSRGB(XDp *InstancePtr, u8 Stream)
* u32 XDp_TxCfgSetYonly(XDp *InstancePtr, u8 Stream)
* u32 XDp_TxCfgSetYCbCr422Bt601(XDp *InstancePtr, u8 Stream)
* u32 XDp_TxCfgSetYCbCr422Bt709(XDp *InstancePtr, u8 Stream)
* u32 XDp_TxCfgSetYCbCr444Bt601(XDp *InstancePtr, u8 Stream)
* u32 XDp_TxCfgSetYCbCr444Bt709(XDp *InstancePtr, u8 Stream)
* u32 XDp_TxCfgSetXvYcc422Bt601(XDp *InstancePtr, u8 Stream)
* u32 XDp_TxCfgSetXvYcc422Bt709(XDp *InstancePtr, u8 Stream)
* u32 XDp_TxCfgSetXvYcc444Bt601(XDp *InstancePtr, u8 Stream)
* u32 XDp_TxCfgSetXvYcc444Bt709(XDp *InstancePtr, u8 Stream)
* u32 XDp_TxCfgSetAdbRGB(XDp *InstancePtr, u8 Stream)
I add it into function of start_tx(),before XDpTxSs_Start().
I am not clear what should the stream param to be set in SST mode,so I instant 4 stream.
Show as below.
Applicataion operating normally,XDp_TxCfgSetXvYcc422Bt709() fuction returns success,but the result is the same as before.Even if every XDp_TxCfgSet**() fuction I had try.
Here is my questions:
Format changing is not supported in this example design?
Could you tell me what should I do next?
Re: dp v2.1 example design color format change
Hi @gandics
In the KC705 example design, the color format is set at the beggining of the TX only part:
DpTxSsInst.DpPtr->TxInstance.MsaConfig[0].ComponentFormat = 0x0;
Msa[0].ComponentFormat = 0x0;
According to the DP1.2 Spec
RGB -> 0x0
YCbCr422 -> 0x01
YCbCr444 -> 10
This is one way you can use.
Another way is by looking at the ZCU102 TX only example design.
In the start_tx funtion you will have:
XDp_TxCfgSetColorEncode(DpTxSsInst.DpPtr, XDP_TX_STREAM_ID1, \
format, XVIDC_BT_601, XDP_DR_CEA);
Where format is the color format defined at the beggining of the application (user_config.user_format = XVIDC_CSF_RGB;).
And finally, no, colour format is not supported in the TX-only part of the example design as the pattern generator in the vivado design only supports RGB. But when you are in path-through mode, TX will replicate the colour format received on RX.
Florent
Hi @gandics
RGB -> 0x0
YCbCr422 -> 0x01
YCbCr444 -> 10
Florent
Hi @florentw
Thanks for your reply!
According to your answer,I have changed the register.
It does work!But the monitor display still incorrectly.
YCbCr422 below:
TPG settting:
SDK part:
Thanks!
Hi @gandics
I encourage you to cross-check the registers value for both the displayport subsystem and the TPG. It might be that one of them is incorrectly programmed.
Also you need to make sure that the option "Enable UG934 Compliance of AXI4-Stream Video Output" in enabled in the DP Tx subsystems to be able to connect the TPG directly. This is not used in the example design
Florent
Hi,@florentw
Probably,due to the pixel mapping difference,I think.
I will monitor the axi4_stream_tdata through ila to position Issue.
Thank you!:)
