fir decination
I want to decinate from 100MHz data to 80MHz , how to  design . the system clk is 100MHz, resoure data sampling rate is 100MHz, the wanted sampling rate is 80MHZ,fir ip 5.0.
can you  attach the design.
Re: fir decination
In the “Filter specification” section of FIR Compile 5.0 select:
-          “Interpolation” as Filter Type
-          “Fixed_Fractional” as Rate  Change Type
-          4 in Interpolation Rate Value
-          5 in Decimation Rate Value
Fill the rest of parameters (coefficients, filter architecture... and so on) according to your specifications.
Good luck,
IKERLAN FPGA
fpga@ikerlan.es
