hdmi_example xapp1275
I got the VCU108 and HDMI 4K FMC Card to test hdmi2.0.
To see block diagrams about HDMI, I found example design.
However, there are only hdmi example about KCU108.
For refer block diagrams, I run the all.tcl file.
There is license error that hdmi_example_kcu_v_tpg_0_0 is locked and requires one or more mandatory licenses.
How can i solve this problem and is there any hdmi2.0 example project related VCU108?
Re: hdmi_example xapp1275
There is not currently an example design for VCU108, so you are on the right path of starting the KCU105 design and moving from there.
The TPG is a free, but licensed core. Meaning you need to go to www.xilinx.com/getlicense and download a license for the TPG (at no cost). Then install it. Then clean and re-run the project after restarting vivado.
www.xilinx.com
