Observer stratix2
hdmi tx ss 1080p30 reference clock 4px/clk native video
In my design hdmi tx ss, resolutions from 1080p50 till 4k60 work fine
native video
GTXE2
QPLL
4px/clk
for 1080p30, 1080p25, 1080p24
pixel clock 74.25MHz
reference clock I give is 74.25MHz, when I look into info it says
         GT status
         TX reference clock frequency: 222765056 Hz
so video phy multiplies it by 3
tmds clk is 89,295MHz
then it gives me back tx_video_clk 37,126‬MHz which is pixel clock/2
but in my design it should be pixel clock/4, which is the case with higher resolutions
is it normal? if so how it should work? should I use VIDEO_IN_active_video pin in hdmi_tx_ss as clock enable and not only for active/blanking?
thank you!
UPD:
the differences in phy registers values for 1080p24 and 1080p60:
                             for 1080p24
phy register #24 0x0018 RO PLL Lock Status (PLS)
in dec : 16 in hex : 00000000
phy register #28 0x001C RW TX Initialization (TXI)
in dec : 16843009 in hex : 01010101
GTTXRESET = '1'
phy register #32 0x0020 RO TX Initialization Status (TXIS)
in dec : 394758 in hex : 00060606
TXRESETDONE = '0'
phy register #120 0x0078 RO TX Status (TXS)
in dec : 0 in hex : 00000000
TXPHALIGNDONE = '0'
phy register #524 0x020C RO Transmitter Frequency
in dec : 222765056 in hex : 0D472000
                 meanwhile for 1080p60
in dec : 16 in hex : 00000010
qpll
in dec : 460551 in hex : 00070707
TXRESETDONE = '1'
in dec : 65793 in hex : 00010101
TXPHALIGNDONE = '1'
in dec : 148510720 in hex : 08DA1800
Tags (2)
Re: hdmi tx ss 1080p30 reference clock 4px/clk native video
HI @stratix2,
The clocking in the system is shown below:
In your system because you are using Quad pixels per clock the Video clock is the Pixel clock/4.
When you say the reference clock given is 74.25Mhz, but the core is reporting this  222765056 Hz, this tells me that there is a clocking problem. Either you are actually giving the core 222.7Mhz or the clock running the clock detector has changed(vid_phy_axi4lite_aclk). **The clock detector is responsible for reporting your reference clocks frequency.
Also as a note:
I see that you are in 7-series (GTX)
2019-09-19 09_54_01-Xilinx Documentation Navigator 2018.3 -  https___www.xilinx.com_support_document.png
2019-09-19 09_45_55-Xilinx Documentation Navigator 2018.3 -  https___www.xilinx.com_support_document.png
2019-09-19 09_52_18-Xilinx Documentation Navigator 2018.3 -  https___www.xilinx.com_support_document.png
Xilinx Video Design Hub
