Observer ain0102
how to fix VDMA S2MM errors
Hello.
VDMA has enabled both read and write channels.
The following error occurs :
S2MM_VDMASR 14bit : Err_Inq
S2MM_VDMASR 11bit : SOFLateErr
S2MM_VDMASR 4 bit : VDMAIntErr
How do I fix the error?
Re: how to fix VDMA S2MM errors
The errors mean the incoming frame size on the AXI Stream interface is different than what you've programmed into the registers.
This is common error at startup or hot plug events where partial frames are possible. This will cause an error in the S2MM_VDMASR register which will be 'sticky' until you clear it.
So I always suggest that you first clear the errors and then read them back to determine if it is a startup issue or stead-state issue. If it's a steady state issue, you need to confirm HSIZE/VSIZE registers and make sure it matches the frame size on the AXI Stream interface.
www.xilinx.com
www.xilinx.com
Hi @bwiec,
Do you have any updates on this?
If  everything clear for you on this subject, please kindly close the topic by marking one reply as accepted solution.
Thanks and Regards,
Florent
