Observer missjr
how to use pixel repetition in HDMI tx for 480i/576i support?
The HDMI tx do not have "field" signal for interlaced mode support, but HDMI rx did.
When i connect HDMI rx to HDMI tx with native mode, the HDMI analyzer show me "pixel repeat" error.
i had check pg235, but i dont know how to understand the section "Interlaced Video with Pixel Repetition".
If i want connect HDMI rx and tx? how to do it?
Re: how to use pixel repetition in HDMI tx for 480i/576i support?
@missjr
I have done some tests with KC705 TX only example design.I can see pixel repetition is enabled.
As per mentioned by @chrisar , you can use following to enable pixel repetition :
AVIInfoFramePtr->PixelRepetition = XHDMIC_PIXEL_REPETITION_FACTOR_2;
I was able to reproduce the issue related to Hsync width. I will report this issue to factory.
BTW, I also notice you are trying to implement 8 color depth for YUV422, which isn't supported. We only support 12 bits color depth for YUV422.
@missjr FID for HDMI TX is used for field input.
Observer missjr
the signal port in HDMI tx core do not have FID.
however, the 1080i60 works well.  that makes me confusing.
i think there have something i misunderstanding. could you please give me a illustration more detailed?
@missjr
Please see the screenshot. If you still can't find FID, please attach your xci file for HDMI TX IP
Observer missjr
@xud i think you had generate HDMI tx core with AXI mode. now i'm using Native mode. i havent found the FID in both Vivado2016.4 and Vivado2017.4.
    attach file is the xci for HDMI tx. please help me have a look.
Scholar watari
Hi @missjr
I guess that you need to adjust a relationship between hsync and vsync for supporting interlace, if you use native mode.
Because of like this format is pointed out by using a relationship between hsync and vsync insted of filed signal.
Best regards,
Observer missjr
@watari the 480i/576i format for SD comes from HDMI rx, but i think the format is properly, the field,hsync and vsync seems fine. we can convert the 480i/576i format from HDMI rx to SDI properly, but we cannot let HDMI tx works well. we had Altera SDI core for compare, when we set 480i/576i in HDMI tx, we should change oversampling from 5 to 10 to support pixel repeat. but i dont know how to set in Xilinx.
@missjr
Currently, HDMI TX doesn’t keep track of the field ID and drop unnecessary field. Users need to have their own logic to make sure the interlaced video are fed to HDMI TX accordingly. Otherwise, there are chances the field 1 from previous frame mixed with field 0 of current frame.
For more details, please refer to page 42-43 of PG235 : https://www.xilinx.com/support/documentation/ip_documentation/v_hdmi_tx_ss/v3_1/pg235-v-hdmi-tx-ss.pdf
Observer missjr
@xud
    we got transfer status as below, i think the format is properly.hdmi status.png
but we got pixel repetition error as below:
the image was not correct at display, so i want know how why the pixel repetition was not asserted?
@missjr
The software driver reports the Video timing information based on VIC code, so the timing in terminal is correct. From the screenshot, I can see your analyser can detect correct VIC code. It seems there is problem with the intervals between two hsync signals, and pixel repetition
Can you add hsync to debug signals, and measure it in ILA? If the hsync in ILA is measured as 128, there might be some problem with IP.
Can you attach your xci file, please? I will check if v2018.1 has this problem.
Observer missjr
@xud
    The HDMI tx xci file in upstairs. the version is vivado2016.4.
    I can use ILA for hsync problem confirm.
    if you need other xci file, please tell me.
@missjr
If you are still using 2016.4, please be aware there is a known issue for 576i :
https://www.xilinx.com/support/answers/68799.html
This issue was initially found in 2016.4, has been fixed in 2018.1.
It's known in 2016.4 that HDMI TXSS doesn't send Pixel Repetition information to the sink.
I strongly recommend you upgrade the version to 2018.1 if possible.
Observer missjr
@xud
    Oh, thanks, i will update to newest version and have a try.
Hi @missjr,
Do you have any updates on this?
If 2018.1 solved your issue, please kinldly close the topic by marking @xud 's reply as accepted solution.
Florent
Observer missjr
@xud
    I had update Vivado from 2016.4 to 2018.1.
    but i got some problem when we use pass thru for hdmi rx and tx. the event shows me the TX stream always up and down. before we update the vivado version, we dont have this problem.
    is hardly to compare the library between 2016.4 and 2018.1.
    does Xilinx have newset hdmi_example source file(such as xhdmi_example.c) can give me for compare?
    i can use the newset example code to verify with the new library which generate by hdf files.
@missjr Please refer to Chapter 5 of PG235/236, it helps you generating the new example design application in 2018.1
Observer missjr
@xud
    after a litter while, may be one minute, the HDMI tx can output video properly, but pixel repetition still not asserted in analyzer.
    the solution at https://www.xilinx.com/support/answers/70238.html shows the user must add pixel repetition logic to compy with HDMI specification.
    do we need it? if that's the case, how to add the pixel repetition logic by user?
@missjr
Can you provide following information?
- take a photo of HDMI analyser when using 2018.1 drivers I will also check if Hsync looks correct.
- xci for your HDMI TX
After I have above files, I will need to discuss with factory, and then get back to you.
Observer missjr
@xud
    the attached file have the photo for hdmi tx analysis, the pixel rep still not right.
In 2018.1, the AUX Packet handling has been rewritten.  There is now a new set of APIs for setting all the necessary parameters in the AVI InfoFrame, including the Pixel Repetition.
You can find the code on how to set the Pixel Repetition in the TxStreamUpCallback function the TX Only Example Design Software xhdmi_example.c.
Chris
Video Design Hub | Embedded SW Support
@missjr
Observer missjr
@xud @chrisar
    Thanks for mention, we set the MAX BPC is 8, not 12, now we still working on intergration newr xhdmi_example.c to ou project, we will change the BPC to 12 later.
    And very appreciate for help us did the verify. We can follow the step by you comments to set the pixel repetition.
