implementation error in inserting ila to the mipi_csi pin
I wanted to debug the mipi csi rx subsystem and inserted the ila to the mipi_csi pin. But i encounted error in implementation.
Tags (2)
Re: implementation error in inserting ila to the mipi_csi pin
Hi @ivanfan,
The error is saying that the full bus can not be placed within the same ILA because some of the signals require different routing. Specifically, some of the signals are clocks that need to be buffered before they are connected to an ILA.
You can try expanding the bus using the "+" and selecting some of the signals which do not require a buffer.
Alternatively, you can add an ILA inside of the MIPI core after the signals are buffered. This will require adding the ILA post-synthesis and not directly in IPI.
Xilinx Video Design Hub
Mentor watari
Mentor
Hi @ivanfan
It is not directly able to connect it.
However, I guess you measure these signals via VIO...
Best regards,
Thank you for your reply.
i am a newcomer in fpga and i don't know how the connect the vio to the interface connection like the mipi_csi pin.
Mentor watari
Mentor
Hi @ivanfan,
Hi @ivanfan
If your question is answered or your issue is solved, please kindly mark the response which helped as a solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
