mipi csi-2 RX operation time limit
I'm using mipi csi-2 rx subsystem ip for mipi camera of Ultra96
It seems to stop ultra96 linux system after it runs about one hour.
Is it normal?
I'm using  180-day evaluation license for it
Re: mipi csi-2 RX operation time limit
Hello @hokim
Yes, it is expected behavior.
1. MIPI CSI-2 RX Subsystem and MIPI CSI-2 TX Subsystem will activated timeout mechanism if evaluation license is used. There is no workaround for this.
2. Re-initialize MIPI IP will not work. You have to power off/on your board or do the FPGA reconfiguration.
3. The time out duration is dependent on the video_aclk frequency, so time-out duration varies based on video_aclk.
    We cannot give more detail information other than this. :-)
4. If the MIPI CSI-2 Rx Subsystem or  MIPI CSI-2 TX Subsystem has time-out activated, all packets are reported as unsupported data types(ErrID) after time-out
     [ For MIPI CSI-2 RX : which means Interrupt Status Register ISR[8] will get set  Refer PG232]
     [ For MIPI CSI-2 TX : which means Interrupt Status Register ISR[1] will get set  Refer PG260]
Thanks & regards
Leo
Hello @hokim
Thanks & regards
Leo
