rdf0428-zcu106-vcu-trd-2018-3 vivado script error
    When I run "vivado -source scripts/vcu_trd_proj.tcl" in rdf0428-zcu106-vcu-trd-2018-3 , click generate bitstream. Some error happens!
Re: rdf0428-zcu106-vcu-trd-2018-3 vivado script error
Hi @liufengwuhen,
Are you building in windows? If yes this is expected. Only a linux os is supported to build the trd.
You are probably facing a path length issue (over 256 characters).
If not, make sure you have no special character in your path.
Hi @liufengwuhen,
HI @liufengwuhen ,
Thanks and Regards,
