Participant liufengwuhen
rdf0428-zcu106-vcu-trd-2018-3 vivado script error
    When I run "vivado -source scripts/vcu_trd_proj.tcl" in rdf0428-zcu106-vcu-trd-2018-3 , click generate bitstream. Some error happens!
Tags (2)
Re: rdf0428-zcu106-vcu-trd-2018-3 vivado script error
Hi @liufengwuhen,
Are you building in windows? If yes this is expected. Only a linux os is supported to build the trd.
You are probably facing a path length issue (over 256 characters).
If not, make sure you have no special character in your path.
Florent
Hi @liufengwuhen,
Florent
HI @liufengwuhen ,
Do you have any updates on this?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
