reagrding HDMI IP
I have a evaluation license for HDMI
But HDMi stops working with the error
create_bd_cell -type ip -vlnv xilinx.com:ip:v_hdmi_tx_ss:3.1 hdmi_display_path/v_hdmi_tx_ss_1
ERROR: [IP_Flow 19-3478] Validation failed for parameter 'My M01_A00_BASE_ADDR(M01_A00_BASE_ADDR)' with value '0x0000000000100000' for BD Cell 'v_hdmi_tx_ss_1/U0/axi_crossbar'. PARAM_VALUE.M01_A00_BASE_ADDR must not overflow the crossbar global ADDR_WIDTH of 17 bits
ERROR: [Common 17-39] 'set_property' failed due to earlier errors.
CRITICAL WARNING: [IP_Flow 19-1747] Failed to deliver file 'c:/Xilinx/Vivado/2018.3/data/ip/xilinx/v_hdmi_tx_ss_v3_1/elaborate/bd.xit': ERROR: [Common 17-39] 'set_property' failed due to earlier errors.
ERROR: [IP_Flow 19-167] Failed to deliver one or more file(s).
ERROR: [IP_Flow 19-3541] IP Elaboration error: Failed to generate IP 'v_hdmi_tx_ss_1'. Failed to generate 'Elaborate BD' outputs: Failed to elaborate IP.
ERROR: [Common 17-39] 'create_bd_cell' failed due to earlier errors
I couldnot use it any more. (This happen after I update my windows)
Please let me know whart could be the issue.
Kind regards
Tags (2)
Re: reagrding HDMI IP
I reinstall the Vivado 2 times.
I think it was due to windwos 10 new update. I have roll back the windows 10 build, now the Vivado works
Hence :
The Vivado 2018.3 is not working with new Windows 10 update.
HI @msh ,
It still look like a licensing issue.
Can you check the column "Host ID match" in Vivado license manager and make sure it is yes. Else, I think you didn't regenerate the license for your new host
Florent
Here I check
HI @msh ,
Could you send your failing project with the vivado.log file?
Thanks and Regards,
Florent
I cannot forward the project due to confidential issuue.
Though I made a example project test, to show the issue. Please find it in the attachment.
Is there any suggestion ?
Kind regards
Hi @msh ,
Thank you for your design. I am able to see in which stage you are stuck. However, If I just change a parameter in the IP configuration, everything is fine again.
Maybe your vivao installation was corrypted. Can you try to re-install it?
Florent
Hence :
