spdif_0_ex
I installed the spdif_0_ex project.  Is there a Block Design available?
Jacques
Re: spdif_0_ex
Hi @jmcm,
I am assuming that you are talking about the example design created by right-clicking on the IP and selecting "Open IP Example Design."
This design is an HDL only design and does not have a block design available.
If you want to see a schematic view, you can optionally see how the design is connected using Open Elaborated Design -> Schematic.
Sam
Xilinx Video Design Hub
Re: spdif_0_ex
Hi @jmcm,
Sam
Re: spdif_0_ex
Hi Sam,
Yes you are correct.  This is how I got Vivado to create the spdif_0_ex project.
Thanks for the tip.  I'll try it.  Is there another SPDIF example project with a BD available?
Jacques
Re: spdif_0_ex
Hi Jacques,
No problem!
I don't know of any BD SPDIF designs at this point.
Sam
