speed kintex 7
Hi;
How can I calculate the speed of Kintex 7 high speed analogue XC7K325T
Re: speed kintex 7
The Fmax cannot be 1.69 GHZ
What is your speed grade?
If you are using the KC705 board the speed grade is -2 and below is the snapshot from ds182 showing the FMAX of DSP48 for different speed grades.dsp48.png
For -2 speedgrade the FMAX is 650.2MHz and it has 840 Dsp's
So GMACs=840*2*650.=1092GMACs  and not otherway around and the Fmax doesn't increase depending on the GMAC requirement.
So
Satish
Re: speed kintex 7
you can check the datasheet for the switching characteristics details of all the blocks.
http://www.xilinx.com/support/documentation/data_sheets/ds182_Kintex_7_Data_Sheet.pdf
if you have design you can check the timing report after implemention for the system frequency which your design will work
--Krishna
Re: speed kintex 7
HI,
What do you mean by "speed of Kintex 7 high speed analogue XC7K325T". Do you mean the max speed of the High speed IO's on kiintex 7? Please elaborate.
Anirudh
Re: speed kintex 7
Hi;
That mean how can i know the maximum clock frequncy for kintex 7 and daughter card ADC/DAC if I have GMACs.
Regards.
Re: speed kintex 7
Check below link for relation between GMAC's,Max frequency
http://forums.xilinx.com/t5/General-Technical-Discussion/understanding-GMACS-and-DSP-slices/td-p/154744
Satish
Re: speed kintex 7
For kintex 7 XC7K325T I have  DSP slices No= 840 How can i calculate the frequancy.
http://www.xilinx.com/products/silicon-devices/fpga/kintex-7.html
Re: speed kintex 7
Hi;
Could anyone correct to me.
I calculated as shown below for kintex-7 XC7K325T
GMACs= DSP Slice * F max * 2
2845= 840 * fmax*2
Fmax = 1.6934... GHz
http://www.xilinx.com/support/answers/41803.html#solution
Re: speed kintex 7
So
Satish
