Visitor chunjiew
tuser is kept more than one cycle in mipi csi-2 rx subsystem
From the last thread https://forums.xilinx.com/t5/Video/mipi-csi-2-rx-subsystem-only-receive-frames-when-fpga-is-powered/td-p/951571, the CRC and ECC are fixed.
When capturing the data output from the mipi csi-2 rx subsystem, the tuser is kept more than ONE clock cycle, which will corrupt the later IP such as axis_subset_convert.
Are there any ideas why the tuser is kept more than 1 clock cycle?
Thank you for your time and any help is appreciated.
Chunjie
Re: tuser is kept more than one cycle in mipi csi-2 rx subsystem
Hi @chunjiew ,
Do you have any updates on this? Is everything clear enough for you?
If your question is answered or your issue is solved, please mark the response which helped as solution (click on the button "Accept as solution" below the reply)
Best Regards,
Visitor chunjiew
Hi @karnanl
Could you take some time to check the issue about tuser signal, which is quite strange? I use the evaluation license.
From the register status, as follows, the IP should work well.
Your time is quite appreciated.
chunjie
Visitor wjn0719
Forgot the IP processing path: MIPI CSI-2 RX -> axis_sub_converter -> demosaic -> VDMA. This path is just for debugging. It seems that demosaic cannot handle bad frame, such as the two consecutive tusr.
Your ideas are appreciated.
Hello @chunjiew
tuser is a multiple bits signal. ( 96bits for 2018.1 MIPI CSI-2 RX SUbsystem )
Could you please check your RTL connectivity ?
tuser[0] should only "high" for one clock every frame (tuser[0] == Start of Frame).
Please let me know if tuser[0] is behave incorrectly on your system, we will need to do some debugging.
Thanks and regards
Leo
Visitor chunjiew
Hi @karnanl
The issue has been fixed as the later demosaic is not working well, so the stream stops.
Thanks again,
Chunjie
HI @chunjiew ,
I do not think we can say that the deinterlacer is not working well. This is an expected behaviour, the deinterlacer expect full frames and is not designed to handle bad frames.
Hello @chunjiew
  1. tuser is a 96 bits of signal. So if your design only enabled tuser[0] in the GUI,
    Please enabled all of 96 bits and could you please share the ILA with us ?
    by enabling all the bits, we can see all the information such as Data type, word count etc
  2. (a) Did you enable “Embedded non-image interface” in your design ?
    (b) Do you have embedded non-image data coming from your sensors ?
    -- If the answer : (a) No, (b) yes
        then this might occurs depends on sensor data.
  3. One more thing, is your sensor has multiple VC of video stream ?
    If yes , please capture TDEST on ILA too.
Thanks & regards
Leo
Hi @chunjiew ,
Best Regards,
Visitor chunjiew
Hi @karnanl  and @florentw
Sorry for the late replay, and many thanks for your answer. The solution has been accepted.
Chunjie
