Observer rjmoss
v2018.3 VCU TRD - HDMI Video Capture Design Module - Help with GStreamer Command Line Failure unless VCU_GST_APP is run first (gst_v4l2_buffer_pool_streamon Broken Pipe)
Versions:
ZCU106 Production Board
HDMI Source Used:  NVIDIA Shield TV (4K)
TRD Bundle:  rdf0428-zcu106-vcu-trd-2018-3.zip (MD5SUM: 7b704ca012ed0e0f5656eed655fa40e7)
Design Module:  https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/31916173/Zynq+UltraScale+MPSoC+VCU+TRD+2018.3+-+HDMI+Video+Capture
1. debug-hdmi-rx_vcu_gst_app.txt : GStreamer debug output captured during execution of vcu_gst_app with HDMI-RX input
2. debug-hdmi-rx_gstreamer_command_line.txt : GStreamer debug output captured during execution of gstreamer command line with HDMI-RX input
3. hdmi-rx_vcu-gst-app_vs_gstreamer_bufferpoolissue.docx : Highlighted comparison of Debug Logs
Issue:
The gstreamer command line for the HDMI Video Capture design module fails unless you first execute the VCU_GST_APP, which must do additional configuration that is not documented for the GStreamer command line example.
Request:
1. Help identify how to properly initialize buffer pool with GStreamer Command Line (so you don't have to run VCU_GST_APP) in order to build HDMI-RX command line examples with the TRD.
How to Replicate on the ZCU106 with the HDMI Video Capture Design Module pre-built images:
A. Failing Example with the GStreamer Command Line
Make sure you're executing these instructions from a clean power-up.
# Configure the V4L2 device output (which will match the expected format for the VCU encoder)
root@zcu106_vcu_trd:~# v4l2-ctl -d /dev/video0 --set-fmt-video=width=3840,height=2160,pixelformat='NV12'
# Configure the scaler input to match the input format of the incoming HDMI Stream
root@zcu106_vcu_trd:~# xmedia-ctl -d /dev/media0 -V '"a0080000.v_proc_ss":0 [fmt:RGB888_1X24/3840x2160]'
# Configure the scaler output to match the V4L2 device output (NV12 is VYYUYY8_1X24)
root@zcu106_vcu_trd:~# xmedia-ctl -d /dev/media0 -V '"a0080000.v_proc_ss":1 [fmt:VYYUYY8_1X24/3840x2160]'
# Execute the GStreamer Command Line Example from the Wiki
root@zcu106_vcu_trd:~# GST_DEBUG=v4l2*:5,v4l2bufferpool:7,vgst*:5,*omx*:5 gst-launch-1.0 -v v4l2src device=/dev/video0 io-mode=4 ! \
video/x-raw, format=NV12, width=3840, height=2160, framerate=60/1 ! \
omxh264enc qp-mode=auto gop-mode=basic gop-length=60 b-frames=0 target-bitrate=10000 num-slices=8 control-rate=constant \
prefetch-buffer=true low-bandwidth=false filler-data=true latency-mode=normal ! \
queue ! mpegtsmux alignment=7 name=mux ! filesink location="/media/usb/hdmi-rx_debug_stream.ts"
# Resulting debug output captures the failure
v4l2bufferpool gstv4l2bufferpool.c:979:gst_v4l2_buffer_pool_flush_stop:<v4l2src0:pool:src> stop flushing
v4l2bufferpool gstv4l2bufferpool.c:641:gst_v4l2_buffer_pool_streamon:<v4l2src0:pool:src> error with STREAMON 32 (Broken pipe)
omxvideoenc gstomxvideoenc.c:3754:gst_omx_video_enc_sink_event:<omxh264enc-omxh264enc0> Upstream allocated 5 buffers
v4l2bufferpool gstv4l2bufferpool.c:1336:gst_v4l2_buffer_pool_acquire_buffer:<v4l2src0:pool:src> acquire
v4l2bufferpool gstv4l2bufferpool.c:1054:gst_v4l2_buffer_pool_poll:<v4l2src0:pool:src> polling device
v4l2bufferpool gstv4l2bufferpool.c:1091:gst_v4l2_buffer_pool_poll:<v4l2src0> error: poll error 1: Broken pipe (32)
v4l2bufferpool gstv4l2bufferpool.c:1308:gst_v4l2_buffer_pool_dqbuf:<v4l2src0:pool:src> poll error error
v4l2src gstv4l2src.c:1105:gst_v4l2src_create:<v4l2src0> error: Failed to allocate a buffer
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not read from resource.
omxvideoenc gstomxvideoenc.c:3316:gst_omx_video_enc_drain:<omxh264enc-omxh264enc0> Draining component
Additional debug info:
../../../git/sys/v4l2/gstv4l2bufferpool.c(1091): gst_v4l2_buffer_pool_poll (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
omxvideoenc gstomxvideoenc.c:3321:gst_omx_video_enc_drain:<omxh264enc-omxh264enc0> Component not started yet
B. Working Example with the VCU_GST_APP executed first
# Execute the VCU_GST_APP
root@zcu106_vcu_trd:~# GST_DEBUG=v4l2*:5,v4l2bufferpool:7,vgst*:5,*omx*:5 /media/card/bin/vcu_gst_app /media/card/config/4kp60/Record/Single_4kp60_AVC_LOW.cfg
NOW STOP the video recording, and re-run the GStreamer command line to initiate a capture with GStreamer
Make sure you're executing these instructions after a successful VCU_GST_APP run
The GStreamer Pipeline works properly if executed after the VCU_GST_APP
Jason
Re: v2018.3 VCU TRD - HDMI Video Capture Design Module - Help with GStreamer Command Line Failure unless VCU_GST_APP is run first (gst_v4l2_buffer_pool_streamon Broken Pipe)
Hello @rjmoss
I have two questions for you to move forward on this
1. what is the HDMI source are you using in this case?
2. What is the output of xmedia-ctl -p -d /dev/media0   ?
Please note before calling the Gst-launch tool you should chose one out of the following media-ctl pipeline and edit it for your resolution to set up the video pipeline.
Let me know if it helps.
Thank you
Hello @rjmoss
I am reproducing this issue on my side.
Spare me some time to get back to you.
Thank You
Hello @rjmoss
Thank you
Observer rjmoss
In case anyone else encounters this, there were two issues with the media device configuration:
  1. Media sub-device configuration was missing the "field:none" parameter
  2. the format for the Sink pad of the scaler was incorrect - this should have been RBG888_1X24, but instead was RGB888_1X24
