what is the main stream video processing structure support by A7 FPGA?
This is the original post
https://forums.xilinx.com/t5/AXI-Infrastructure/Are-there-any-updates-for-xapp789/m-p/846543#M667
I am using A7 FPGA for a group of new projects. That seems a main stream video processing structure is quite necessary to be considered at the early stage. Generally the A7 fpga is working with 32bits DDR3 chip and DVP based cmos image sensors. It is required:
1) more than one channel video stream go into DDR3 frame buffer.
2) one or two video output channel sink the image data from ddr3. Such as HDMI output and USB3.0 output.
If any app note is created as common platform to my application? xapp789 is just looks like a legacy note.
Voyager
Voyager
Re: what is the main stream video processing structure support by A7 FPGA?
I tried a search on the Xilinx.com website for "video reference designs".  Several XAPPs came up:
XAPP1291 - Video Processing Subsystem Reference Design Application Note
XAPP742 - AXI VDMA Reference Design
XAPP596 - 4K2K Up-Converter Reference Design Application Note
XAPP1216 - AXI Chip2Chip Reference Design for Real-Time Video Applications
XAPP794 - 1080p60 Camera Image Processing Reference Design
XAPP1244 - JPEG 2000 and SMPTE 2022 Video over IP Reference Design Application Note
XAPP1264 - Real Time Video Engine 3.1 Implementation in Zynq‐7000 All Programmable SoCs
Maybe one of these will help.
Ted Booth - Tech. Lead FPGA Design Engineer
www.designlinxhs.com
Voyager
Voyager
Hi @rggber,
Do you have what you need? If yes, please kindly mark @tedbooth 's response as accepted solution to close the topic.
Florent
