xilinx-vcu : Could not get core_enc clock
I am running a VCU TRD design based on the ZCU106 and am running into an issue where the VCU Core Encoder clock fails resulting in the following message:
Does any one know why this would happen?
Thanks!
Re: xilinx-vcu : Could not get core_enc clock
Hi @kvasantr  and @watari
I was able to resolve this issue by rebuilding the pl and recompiling the kernel. Thanks for your input and help!
Mentor watari
Mentor
Hi tkato@poc.com
What version are you using ? 2019.1 ? 2019.2 ? or other ?
If 2019.1, I have never seen like this message.
Hi @watari
Using 2019.1 in drivers/soc/xilinx/xlnx_vcu.c in the probe function:
static int xvcu_probe(struct platform_device *pdev)
	xvcu->core_enc = devm_clk_get(pdev->dev.parent, "vcu_core_enc");
	if (IS_ERR(xvcu->core_enc)) {
		dev_err(&pdev->dev, "Could not get core_enc clock\n");
		return PTR_ERR(xvcu->core_enc);
Mentor watari
Mentor
Hi tkato@poc.com
As I already mentioned before, I had already evaluated VCU TRD 2019.1 by gstreamer and have never seen like this message.
In your case, I suspect clock setting or using different version between pmufw and linux kernel/dtb.
Make sure boot log about clock message.
tkato@poc.com wrote:
[Florent] - This is very unclear. Are you using the ZCU106 or a custom board?
What changed did you do compared to the VCU TRD? Do you get the same error with the pre-built image of the VCU TRD?
Hello tkato@poc.com
The issue is with your device tree and this error print is coming from the following code:
https://github.com/Xilinx/linux-xlnx/blob/master/drivers/soc/xilinx/xlnx_vcu.c#L276
The generic function devm_clk_get tries to read the clock from the device tree and if it cannot find this particular property in the device tree binding then it returns this error.
Refer following link as an example for VCU device tree:
https://github.com/Xilinx/linux-xlnx/blob/master/Documentation/devicetree/bindings/soc/xilinx/xlnx%2Cvcu.txt
