Visitor omerfirmak
xilinx-video driver fails at graph parsing
Dmesg output:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 4.19.0-xilinx-v2019.1 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP Fri Sep 6 11:19:51 UTC 2019
[    0.000000] Machine model: ZynqMP ZCU106 RevA
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 1700 MiB at 0x000000000ac00000
[    0.000000] On node 0 totalpages: 1048320
[    0.000000]   DMA32 zone: 7165 pages used for memmap
[    0.000000]   DMA32 zone: 0 pages reserved
[    0.000000]   DMA32 zone: 524032 pages, LIFO batch:63
[    0.000000]   Normal zone: 7168 pages used for memmap
[    0.000000]   Normal zone: 524288 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8 with crng_init=0
[    0.000000] percpu: Embedded 23 pages/cpu @(____ptrval____) s53656 r8192 d32360 u94208
[    0.000000] pcpu-alloc: s53656 r8192 d32360 u94208 alloc=23*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1033987
[    0.000000] Kernel command line: earlycon clk_ignore_unused consoleblank=0 cma=1700M uio_pdrv_genirq.of_id=generic-uio
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB: mapped [mem 0x06c00000-0x0ac00000] (64MB)
[    0.000000] Memory: 2160824K/4193280K available (10812K kernel code, 638K rwdata, 5444K rodata, 832K init, 509K bss, 291656K reserved, 1740800K cma-reserved)
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x170f8de2d3, max_idle_ns: 440795206112 ns
[    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
[    0.008271] Console: colour dummy device 80x25
[    0.012376] console [tty0] enabled
[    0.015743] bootconsole [cdns0] disabled
[    0.019655] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.98 BogoMIPS (lpj=399960)
[    0.019669] pid_max: default: 32768 minimum: 301
[    0.019783] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.019802] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.020532] ASID allocator initialised with 32768 entries
[    0.020585] rcu: Hierarchical SRCU implementation.
[    0.020930] EFI services will not be available.
[    0.021050] smp: Bringing up secondary CPUs ...
[    0.021329] Detected VIPT I-cache on CPU1
[    0.021358] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.021663] Detected VIPT I-cache on CPU2
[    0.021682] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.021972] Detected VIPT I-cache on CPU3
[    0.021991] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.022034] smp: Brought up 1 node, 4 CPUs
[    0.022068] SMP: Total of 4 processors activated.
[    0.022076] CPU features: detected: 32-bit EL0 Support
[    0.023617] CPU: All CPU(s) started at EL2
[    0.023633] alternatives: patching kernel code
[    0.024533] devtmpfs: initialized
[    0.029884] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.029908] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.065719] xor: measuring software checksum speed
[    0.104046]    8regs     :  2375.000 MB/sec
[    0.144074]    8regs_prefetch:  2052.000 MB/sec
[    0.184103]    32regs    :  2724.000 MB/sec
[    0.224131]    32regs_prefetch:  2308.000 MB/sec
[    0.224140] xor: using function: 32regs (2724.000 MB/sec)
[    0.224155] pinctrl core: initialized pinctrl subsystem
[    0.224801] NET: Registered protocol family 16
[    0.225084] audit: initializing netlink subsys (disabled)
[    0.225152] audit: type=2000 audit(0.216:1): state=initialized audit_enabled=0 res=1
[    0.225556] cpuidle: using governor menu
[    0.225695] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.225708] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.226398] DMA: preallocated 256 KiB pool for atomic allocations
[    0.240988] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.308346] raid6: int64x1  gen()   446 MB/s
[    0.376307] raid6: int64x1  xor()   453 MB/s
[    0.444378] raid6: int64x2  gen()   680 MB/s
[    0.512422] raid6: int64x2  xor()   599 MB/s
[    0.580437] raid6: int64x4  gen()   981 MB/s
[    0.648471] raid6: int64x4  xor()   736 MB/s
[    0.716556] raid6: int64x8  gen()  1162 MB/s
[    0.784555] raid6: int64x8  xor()   759 MB/s
[    0.852619] raid6: neonx1   gen()   735 MB/s
[    0.920676] raid6: neonx1   xor()   879 MB/s
[    0.988711] raid6: neonx2   gen()  1127 MB/s
[    1.056757] raid6: neonx2   xor()  1172 MB/s
[    1.124787] raid6: neonx4   gen()  1476 MB/s
[    1.192850] raid6: neonx4   xor()  1417 MB/s
[    1.260892] raid6: neonx8   gen()  1530 MB/s
[    1.328946] raid6: neonx8   xor()  1459 MB/s
[    1.328954] raid6: using algorithm neonx8 gen() 1530 MB/s
[    1.328961] raid6: .... xor() 1459 MB/s, rmw enabled
[    1.328969] raid6: using neon recovery algorithm
[    1.329196] xilinx-gpio a0060000.gpio: Input clock not found
[    1.329240] xilinx-gpio a0061000.gpio: Input clock not found
[    1.329279] xilinx-gpio a0062000.gpio: Input clock not found
[    1.329318] xilinx-gpio a0063000.gpio: Input clock not found
[    1.329958] SCSI subsystem initialized
[    1.330003] libata version 3.00 loaded.
[    1.330144] usbcore: registered new interface driver usbfs
[    1.330182] usbcore: registered new interface driver hub
[    1.330223] usbcore: registered new device driver usb
[    1.330290] media: Linux media interface: v0.10
[    1.330318] videodev: Linux video capture interface: v2.00
[    1.330349] pps_core: LinuxPPS API ver. 1 registered
[    1.330358] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.330378] PTP clock support registered
[    1.330405] EDAC MC: Ver: 3.0.0
[    1.330806] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver.
[    1.331024] FPGA manager framework
[    1.331193] Advanced Linux Sound Architecture Driver Initialized.
[    1.331485] Bluetooth: Core ver 2.22
[    1.331512] NET: Registered protocol family 31
[    1.331520] Bluetooth: HCI device and connection manager initialized
[    1.331533] Bluetooth: HCI socket layer initialized
[    1.331542] Bluetooth: L2CAP socket layer initialized
[    1.331566] Bluetooth: SCO socket layer initialized
[    1.331880] clocksource: Switched to clocksource arch_sys_counter
[    1.331956] VFS: Disk quotas dquot_6.6.0
[    1.332002] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.336474] NET: Registered protocol family 2
[    1.336850] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes)
[    1.336901] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    1.337108] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    1.337504] TCP: Hash tables configured (established 32768 bind 32768)
[    1.337571] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    1.337649] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    1.337802] NET: Registered protocol family 1
[    1.338012] RPC: Registered named UNIX socket transport module.
[    1.338021] RPC: Registered udp transport module.
[    1.338028] RPC: Registered tcp transport module.
[    1.338035] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.338286] PCI: CLS 0 bytes, default 64
[    1.338384] Trying to unpack rootfs image as initramfs...
[    7.571159] Freeing initrd memory: 142872K
[    7.571583] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    7.571749] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    7.572781] Initialise system trusted keyrings
[    7.572863] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[    7.573551] NFS: Registering the id_resolver key type
[    7.573568] Key type id_resolver registered
[    7.573575] Key type id_legacy registered
[    7.573588] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    7.573608] jffs2: version 2.2. (NAND) \xc2\xa9 2001-2006 Red Hat, Inc.
[    8.661493] NET: Registered protocol family 38
[    8.720770] Key type asymmetric registered
[    8.720780] Asymmetric key parser 'x509' registered
[    8.720827] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    8.720840] io scheduler noop registered
[    8.720848] io scheduler deadline registered
[    8.720897] io scheduler cfq registered (default)
[    8.720905] io scheduler mq-deadline registered
[    8.720913] io scheduler kyber registered
[    8.722675] xilinx-frmbuf b0030000.v_frmbuf_wr: failed to get ap_clk (-517)
[    8.722720] xilinx-frmbuf b0000000.v_frmbuf_wr: failed to get ap_clk (-517)
[    8.749176] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    8.753181] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    8.757684] brd: module loaded
[    8.761573] loop: module loaded
[    8.762586] mtdoops: mtd device (mtddev=name/number) must be supplied
[    8.764009] libphy: Fixed MDIO Bus: probed
[    8.765305] tun: Universal TUN/TAP device driver, 1.6
[    8.765448] CAN device driver interface
[    8.766588] usbcore: registered new interface driver asix
[    8.766627] usbcore: registered new interface driver ax88179_178a
[    8.766659] usbcore: registered new interface driver cdc_ether
[    8.766691] usbcore: registered new interface driver net1080
[    8.766722] usbcore: registered new interface driver cdc_subset
[    8.766758] usbcore: registered new interface driver zaurus
[    8.766798] usbcore: registered new interface driver cdc_ncm
[    8.767370] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    8.767380] ehci-pci: EHCI PCI platform driver
[    8.767719] usbcore: registered new interface driver uas
[    8.767760] usbcore: registered new interface driver usb-storage
[    8.768398] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    8.768476] i2c /dev entries driver
[    8.768858] xilinx-video amba_pl@0:vcap_mipi: /amba_pl@0/vcap_mipi/ports/port@0 initialization failed
[    8.768872] xilinx-video amba_pl@0:vcap_mipi: DMA initialization failed
[    8.768920] xilinx-video amba_pl@0:vcap_sdi: /amba_pl@0/vcap_sdi/ports/port@0 initialization failed
[    8.768933] xilinx-video amba_pl@0:vcap_sdi: DMA initialization failed
[    8.769315] xilinx-csi2rxss a0000000.mipi_csi2_rx_subsystem: failed to get lite_aclk (-517)
[    8.770102] xilinx-sdirxss a0030000.v_smpte_uhdsdi_rx_ss: failed to get s_axi_clk (-517)
[    8.770503] xilinx-vpss-scaler a0080000.v_proc_ss: xlnx,v-vpss-scaler - compatible string is getting deprecated!
[    8.770517] xilinx-vpss-scaler a0080000.v_proc_ss: assuming all required clocks are enabled!
[    8.770770] usbcore: registered new interface driver uvcvideo
[    8.770779] USB Video Class driver (1.1.1)
[    8.771373] Bluetooth: HCI UART driver ver 2.3
[    8.771385] Bluetooth: HCI UART protocol H4 registered
[    8.771393] Bluetooth: HCI UART protocol BCSP registered
[    8.771421] Bluetooth: HCI UART protocol LL registered
[    8.771429] Bluetooth: HCI UART protocol ATH3K registered
[    8.771456] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    8.771506] Bluetooth: HCI UART protocol Intel registered
[    8.771534] Bluetooth: HCI UART protocol QCA registered
[    8.771574] usbcore: registered new interface driver bcm203x
[    8.771609] usbcore: registered new interface driver bpa10x
[    8.771647] usbcore: registered new interface driver bfusb
[    8.771682] usbcore: registered new interface driver btusb
[    8.771691] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    8.771742] usbcore: registered new interface driver ath3k
[    8.771897] EDAC MC: ECC not enabled
[    8.772136] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    8.772870] sdhci: Secure Digital Host Controller Interface driver
[    8.772879] sdhci: Copyright(c) Pierre Ossman
[    8.772886] sdhci-pltfm: SDHCI platform and OF driver helper
[    8.773253] ledtrig-cpu: registered to indicate activity on CPUs
[    8.773303] zynqmp_firmware_probe Platform Management API v1.1
[    8.773313] zynqmp_firmware_probe Trustzone version v1.0
[    8.776169] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
[    8.797909] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22
[    8.798409] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[    8.798431] zynqmp_aes zynqmp_aes: AES Successfully Registered
[    8.798627] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[    8.798806] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[    8.799025] usbcore: registered new interface driver usbhid
[    8.799035] usbhid: USB HID core driver
[    8.801571] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    8.801994] usbcore: registered new interface driver snd-usb-audio
[    8.802981] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    8.803364] Initializing XFRM netlink socket
[    8.803443] NET: Registered protocol family 10
[    8.803800] Segment Routing with IPv6
[    8.803918] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    8.804264] NET: Registered protocol family 17
[    8.804280] NET: Registered protocol family 15
[    8.804298] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    8.804337] can: controller area network core (rev 20170425 abi 9)
[    8.804368] NET: Registered protocol family 29
[    8.804377] can: raw protocol (rev 20170425)
[    8.804385] can: broadcast manager protocol (rev 20170425 t)
[    8.804395] can: netlink gateway (rev 20170425) max_hops=1
[    8.804635] Bluetooth: RFCOMM TTY layer initialized
[    8.804648] Bluetooth: RFCOMM socket layer initialized
[    8.804665] Bluetooth: RFCOMM ver 1.11
[    8.804676] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    8.804684] Bluetooth: BNEP filters: protocol multicast
[    8.804694] Bluetooth: BNEP socket layer initialized
[    8.804702] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    8.804712] Bluetooth: HIDP socket layer initialized
[    8.804836] 9pnet: Installing 9P2000 support
[    8.804857] Key type dns_resolver registered
[    8.805257] registered taskstats version 1
[    8.805266] Loading compiled-in X.509 certificates
[    8.805604] Btrfs loaded, crc32c=crc32c-generic
[    8.812111] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 42, base_baud = 6249375) is a xuartps
[   10.177013] console [ttyPS0] enabled
[   10.181063] GPIO IRQ not connected
[   10.184466] XGpio: gpio@a0060000: registered, base is 510
[   10.190042] GPIO IRQ not connected
[   10.193442] XGpio: gpio@a0061000: registered, base is 509
[   10.199018] GPIO IRQ not connected
[   10.202416] XGpio: gpio@a0062000: registered, base is 508
[   10.207997] GPIO IRQ not connected
[   10.211393] XGpio: gpio@a0063000: registered, base is 504
[   10.217723] of-fpga-region fpga-full: FPGA Region probed
[   10.223866] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[   10.230465] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[   10.237576] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[   10.244686] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[   10.251796] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[   10.258903] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[   10.266024] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[   10.273134] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[   10.280254] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[   10.287430] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[   10.294543] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[   10.301651] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[   10.308760] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[   10.315880] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[   10.322986] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[   10.330104] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[   10.337216] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[   10.344318] xilinx-frmbuf b0030000.v_frmbuf_wr: Xilinx AXI frmbuf DMA_DEV_TO_MEM
[   10.351781] xilinx-frmbuf b0030000.v_frmbuf_wr: Xilinx AXI FrameBuffer Engine Driver Probed!!
[   10.360439] xilinx-frmbuf b0000000.v_frmbuf_wr: Xilinx AXI frmbuf DMA_DEV_TO_MEM
[   10.367906] xilinx-frmbuf b0000000.v_frmbuf_wr: Xilinx AXI FrameBuffer Engine Driver Probed!!
[   10.376792] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes
[   10.387787] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[   10.398488] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[   10.406540] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[   10.415198] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[   10.427655] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[   10.440399] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
[   10.450589] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[   10.457602] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   10.464213] [drm] No driver support for vblank timestamp query.
[   10.470209] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008bcf900)
[   11.555890] [drm] Cannot find any crtc or sizes
[   11.560644] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
[   11.568757] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
[   11.577746] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes
[   11.585635] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[   11.594599] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[   11.604996] scsi host0: ahci-ceva
[   11.608564] scsi host1: ahci-ceva
[   11.612023] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 40
[   11.619947] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 40
[   11.628542] m25p80 spi0.0: found n25q512a, expected m25p80
[   11.634533] m25p80 spi0.0: n25q512a (131072 Kbytes)
[   11.639433] 4 fixed-partitions partitions found on MTD device spi0.0
[   11.645782] Creating 4 MTD partitions on "spi0.0":
[   11.650568] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
[   11.656778] 0x000000100000-0x000000600000 : "qspi-linux"
[   11.662496] 0x000000600000-0x000000620000 : "qspi-device-tree"
[   11.668715] 0x000000620000-0x000000c00000 : "qspi-rootfs"
[   11.676599] macb ff0e0000.ethernet: Not enabling partial store and forward
[   11.683965] libphy: MACB_mii_bus: probed
[   11.693036] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL)
[   11.706085] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 30 (00:0a:35:00:22:01)
[   11.716311] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[   11.722878] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[   11.729376] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[   11.735888] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[   11.743726] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
[   11.749582] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes
[   11.757658] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   11.763153] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[   11.771136] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000202010810
[   11.780555] xhci-hcd xhci-hcd.0.auto: irq 53, io mem 0xfe200000
[   11.786686] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[   11.794954] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   11.802171] usb usb1: Product: xHCI Host Controller
[   11.807046] usb usb1: Manufacturer: Linux 4.19.0-xilinx-v2019.1 xhci-hcd
[   11.813743] usb usb1: SerialNumber: xhci-hcd.0.auto
[   11.818898] hub 1-0:1.0: USB hub found
[   11.822676] hub 1-0:1.0: 1 port detected
[   11.826795] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   11.832282] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[   11.839948] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0  SuperSpeed
[   11.846678] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[   11.854949] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   11.862175] usb usb2: Product: xHCI Host Controller
[   11.867049] usb usb2: Manufacturer: Linux 4.19.0-xilinx-v2019.1 xhci-hcd
[   11.873751] usb usb2: SerialNumber: xhci-hcd.0.auto
[   11.878878] hub 2-0:1.0: USB hub found
[   11.882643] hub 2-0:1.0: 1 port detected
[   11.887755] pca953x 0-0020: 0-0020 supply vcc not found, using dummy regulator
[   11.895015] pca953x 0-0020: Linked as a consumer to regulator.0
[   11.901664] pca953x 0-0021: 0-0021 supply vcc not found, using dummy regulator
[   11.908910] pca953x 0-0021: Linked as a consumer to regulator.0
[   11.916224] ina2xx 3-0040: power monitor ina226 (Rshunt = 5000 uOhm)
[   11.923009] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[   11.929801] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[   11.936592] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[   11.942083] ata2: SATA link down (SStatus 0 SControl 330)
[   11.943398] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[   11.948387] ata1: SATA link down (SStatus 0 SControl 330)
[   11.955126] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[   11.966862] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[   11.973659] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[   11.980463] ina2xx 3-004a: power monitor ina226 (Rshunt = 5000 uOhm)
[   11.987250] ina2xx 3-004b: power monitor ina226 (Rshunt = 5000 uOhm)
[   11.993635] i2c i2c-0: Added multiplexed i2c bus 3
[   11.999060] ina2xx 4-0040: power monitor ina226 (Rshunt = 2000 uOhm)
[   12.005856] ina2xx 4-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.012651] ina2xx 4-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.019437] ina2xx 4-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.026228] ina2xx 4-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.033019] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.039811] ina2xx 4-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.046607] ina2xx 4-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.052990] i2c i2c-0: Added multiplexed i2c bus 4
[   12.075811] random: fast init done
[   12.094602] i2c i2c-0: Added multiplexed i2c bus 5
[   12.099529] i2c i2c-0: Added multiplexed i2c bus 6
[   12.104322] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
[   12.111654] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 32
[   12.119359] at24 7-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[   12.126097] i2c i2c-1: Added multiplexed i2c bus 7
[   12.131094] i2c i2c-1: Added multiplexed i2c bus 8
[   12.136007] i2c i2c-1: Added multiplexed i2c bus 9
[   12.154869] si570 10-005d: registered, current frequency 148500000 Hz
[   12.161341] i2c i2c-1: Added multiplexed i2c bus 10
[   12.166427] si5324 11-0069: si5328 probed
[   12.228028] si5324 11-0069: si5328 probe successful
[   12.232936] i2c i2c-1: Added multiplexed i2c bus 11
[   12.238022] i2c i2c-1: Added multiplexed i2c bus 12
[   12.243022] i2c i2c-1: Added multiplexed i2c bus 13
[   12.248018] i2c i2c-1: Added multiplexed i2c bus 14
[   12.252902] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
[   12.260810] i2c i2c-1: Added multiplexed i2c bus 15
[   12.265816] i2c i2c-1: Added multiplexed i2c bus 16
[   12.270827] i2c i2c-1: Added multiplexed i2c bus 17
[   12.276229] i2c i2c-1: Added multiplexed i2c bus 18
[   12.281232] i2c i2c-1: Added multiplexed i2c bus 19
[   12.286242] i2c i2c-1: Added multiplexed i2c bus 20
[   12.291252] i2c i2c-1: Added multiplexed i2c bus 21
[   12.296267] i2c i2c-1: Added multiplexed i2c bus 22
[   12.301148] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
[   12.308741] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 33
[   12.315002] xilinx-video amba_pl@0:vcap_mipi: graph parsing failed
[   12.321281] xilinx-video: probe of amba_pl@0:vcap_mipi failed with error -22
[   12.328650] xilinx-video amba_pl@0:vcap_sdi: device registered
[   12.334838] zynqmp_clk_divider_set_rate() set divider failed for pl3_ref_div1, ret = -22
[   12.343044] xilinx-csi2rxss a0000000.mipi_csi2_rx_subsystem: Xilinx CSI2 Rx Subsystem device found!
[   12.352360] xilinx-video amba_pl@0:vcap_sdi: Entity type for entity a0030000.v_smpte_uhdsdi_rx_ss was not initialized!
[   12.363056] xilinx-sdirxss a0030000.v_smpte_uhdsdi_rx_ss: Xilinx SDI Rx Subsystem device found!
[   12.371922] xilinx-vpss-scaler a0080000.v_proc_ss: xlnx,v-vpss-scaler - compatible string is getting deprecated!
[   12.382102] xilinx-vpss-scaler a0080000.v_proc_ss: assuming all required clocks are enabled!
[   12.390583] xilinx-video amba_pl@0:vcap_sdi: Entity type for entity a0080000.v_proc_ss was not initialized!
[   12.400566] xilinx-vpss-scaler a0080000.v_proc_ss: Num Hori Taps 8
[   12.406753] xilinx-vpss-scaler a0080000.v_proc_ss: Num Vert Taps 8
[   12.412931] xilinx-vpss-scaler a0080000.v_proc_ss: VPSS Scaler Probe Successful
[   12.420537] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at (____ptrval____) with timeout 60s
[   12.429741] cdns-wdt ff150000.watchdog: Xilinx Watchdog Timer at (____ptrval____) with timeout 10s
[   12.438988] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1199880 KHz
[   12.446437] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
[   12.487217] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
[   12.503258] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[   12.510313] rtc_zynqmp ffa60000.rtc: setting system clock to 2019-07-17 18:17:42 UTC (1563387462)
[   12.519191] of_cfs_init
[   12.521642] of_cfs_init: OK
[   12.524578] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   12.568000] mmc0: new high speed SDHC card at address aaaa
[   12.574038] mmcblk0: mmc0:aaaa SB16G 14.8 GiB
[   12.582759]  mmcblk0: p1
[   12.669076] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   12.675609] clk: Not disabling unused clocks
[   12.679877] ALSA device list:
[   12.682835]   #0: DisplayPort monitor
[   12.686755] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   12.695370] cfg80211: failed to load regulatory.db
[   12.700460] Freeing unused kernel memory: 832K
[   12.723893] [drm] Cannot find any crtc or sizes
[   12.723919] Run /init as init process
[   12.878867] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   12.923020] udevd[2007]: starting version 3.2.5
[   12.927903] random: udevd: uninitialized urandom read (16 bytes read)
[   12.934396] random: udevd: uninitialized urandom read (16 bytes read)
[   12.940893] random: udevd: uninitialized urandom read (16 bytes read)
[   12.952238] udevd[2008]: starting eudev-3.2.5
[   13.008912] mali: loading out-of-tree module taints kernel.
[   13.344702] xilinx-vcu xilinx-vcu: Could not get core_enc clock
[   13.351447] VCU PLL: enable
[   13.355292] xilinx-vcu xilinx-vcu: xvcu_probe: Probed successfully
[   13.384184] al5d a0120000.al5d: l2 prefetch size:9175040 (bits), l2 color bitdepth:8
[   13.385782] al5e a0100000.al5e: l2 prefetch size:9175040 (bits), l2 color bitdepth:8
[   13.933053] pps pps0: new PPS source ptp0
[   13.937079] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
[   13.943792] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   14.956276] macb ff0e0000.ethernet eth0: link up (1000/Full)
[   14.961957] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 1082.378370] random: crng init done
[ 1082.381767] random: 7 urandom warning(s) missed due to ratelimiting
pl.dtsi
 * CAUTION: This file is automatically generated by Xilinx.
 * Version:
 * Today is: Mon Sep  9 12:19:41 2019
	amba_pl: amba_pl@0 {
		#address-cells = <2>;
		#size-cells = <2>;
		compatible = "simple-bus";
		ranges ;
		axi_gpio_0: gpio@a0060000 {
			#gpio-cells = <3>;
			clock-names = "s_axi_aclk";
			clocks = <&zynqmp_clk 71>;
			compatible = "xlnx,axi-gpio-2.0", "xlnx,xps-gpio-1.00.a";
			gpio-controller ;
			reg = <0x0 0xa0060000 0x0 0x1000>;
			xlnx,all-inputs = <0x0>;
			xlnx,all-inputs-2 = <0x0>;
			xlnx,all-outputs = <0x1>;
			xlnx,all-outputs-2 = <0x0>;
			xlnx,dout-default = <0x00000001>;
			xlnx,dout-default-2 = <0x00000000>;
			xlnx,gpio-width = <0x2>;
			xlnx,gpio2-width = <0x20>;
			xlnx,interrupt-present = <0x0>;
			xlnx,is-dual = <0x0>;
			xlnx,tri-default = <0xFFFFFFFF>;
			xlnx,tri-default-2 = <0xFFFFFFFF>;
		gpio_register_axis_fifo_gpio: gpio@a0061000 {
			#gpio-cells = <3>;
			gpio-controller ;
			reg = <0x0 0xa0061000 0x0 0x1000>;
			xlnx,dout-default = <0x00000000>;
			xlnx,gpio-width = <0x1>;
		gpio_register_si5324_lol_gpio: gpio@a0062000 {
			#gpio-cells = <3>;
			gpio-controller ;
			reg = <0x0 0xa0062000 0x0 0x1000>;
			xlnx,all-inputs = <0x1>;
			xlnx,all-outputs = <0x0>;
		gpio_resets_axi_gpio_resets: gpio@a0063000 {
			#gpio-cells = <3>;
			gpio-controller ;
			reg = <0x0 0xa0063000 0x0 0x1000>;
			xlnx,dout-default = <0x00000003>;
			xlnx,gpio-width = <0x4>;
		mipi_csi2_rx_mipi_csi2_rx_subsystem_0: mipi_csi2_rx_subsystem@a0000000 {
			clock-names = "lite_aclk", "dphy_clk_200M", "video_aclk";
			clocks = <&zynqmp_clk 71>, <&zynqmp_clk 74>, <&zynqmp_clk 72>;
			compatible = "xlnx,mipi-csi2-rx-subsystem-4.0", "xlnx,mipi-csi2-rx-subsystem-4.0";
			interrupt-names = "csirxss_csi_irq";
			interrupt-parent = <&gic>;
			interrupts = <0 91 4>;
			reg = <0x0 0xa0000000 0x0 0x10000>;
			xlnx,axis-tdata-width = <64>;
			xlnx,cal-mode = "NONE";
			xlnx,clk-io-swap = "false";
			xlnx,clk-lane-io-position = <0x20>;
			xlnx,clk-lp-io-swap = "false";
			xlnx,csi-en-activelanes = "true";
			xlnx,csi-en-crc = "true";
			xlnx,csi-filter-userdatatype = "false";
			xlnx,csi-opt1-regs = "false";
			xlnx,csi-pxl-format = "YUV422_8bit";
			xlnx,csi2rx-dbg = <0x0>;
			xlnx,data-lane0-io-position = <0x2b>;
			xlnx,data-lane1-io-position = <0x20>;
			xlnx,data-lane2-io-position = <0x11>;
			xlnx,data-lane3-io-position = <0x29>;
			xlnx,dl0-io-swap = "false";
			xlnx,dl0-lp-io-swap = "false";
			xlnx,dl1-io-swap = "false";
			xlnx,dl1-lp-io-swap = "false";
			xlnx,dl2-io-swap = "false";
			xlnx,dl2-lp-io-swap = "false";
			xlnx,dl3-io-swap = "false";
			xlnx,dl3-lp-io-swap = "false";
			xlnx,dphy-lanes = <0x1>;
			xlnx,dphy-mode = "SLAVE";
			xlnx,en-active-lanes ;
			xlnx,en-bg0-pin0 = "false";
			xlnx,en-bg0-pin6 = "false";
			xlnx,en-bg1-pin0 = "false";
			xlnx,en-bg1-pin6 = "false";
			xlnx,en-bg2-pin0 = "false";
			xlnx,en-bg2-pin6 = "false";
			xlnx,en-bg3-pin0 = "false";
			xlnx,en-bg3-pin6 = "true";
			xlnx,en-clk300m = "false";
			xlnx,en-csi-v2-0 = "false";
			xlnx,en-exdesigns = "false";
			xlnx,en-timeout-regs = "false";
			xlnx,en-vcx = "false";
			xlnx,esc-timeout = <0x6400>;
			xlnx,exdes-board = "ZCU102";
			xlnx,exdes-config = "MIPI_Video_Pipe_Camera_to_Display";
			xlnx,exdes-fmc = "LI-IMX274MIPI-FMC V1.0 Single Sensor";
			xlnx,fifo-rd-en-control = "true";
			xlnx,hs-line-rate = <0x1b0>;
			xlnx,hs-settle-ns = <0x9e>;
			xlnx,hs-timeout = <0x10005>;
			xlnx,idly-group-name = "mipi_csi2rx_idly_group";
			xlnx,idly-tap = <0x1>;
			xlnx,init = <0x186a0>;
			xlnx,is-7series = "false";
			xlnx,is-versal = "false";
			xlnx,max-lanes = <1>;
			xlnx,mipi-slv-int = <0x0>;
			xlnx,ppc = <2>;
			xlnx,share-idlyctrl = "false";
			xlnx,stretch-line-rate = <0x5dc>;
			xlnx,vc = <4>;
			csiss_ports: ports {
				#address-cells = <1>;
				#size-cells = <0>;
				csiss_port0: port@0 {
					/* Fill cfa-pattern=rggb for raw data types, other fields video-format and video-width user needs to fill */
					reg = <0>;
					xlnx,cfa-pattern = "rggb";
					xlnx,video-format = <12>;
					xlnx,video-width = <8>;
					csiss_out: endpoint {
						remote-endpoint = <&vcap_mipi_in>;
				csiss_port1: port@1 {
					/* Fill cfa-pattern=rggb for raw data types, other fields video-format,video-width user needs to fill */
					/* User need to add something like remote-endpoint=<&out> under the node csiss_in:endpoint */
					reg = <1>;
					csiss_in: endpoint {
		mipi_csi2_rx_v_frmbuf_wr_0: v_frmbuf_wr@b0030000 {
			#dma-cells = <1>;
			clock-names = "ap_clk";
			clocks = <&zynqmp_clk 72>;
			compatible = "xlnx,v-frmbuf-wr-2.1", "xlnx,axi-frmbuf-wr-v2.1";
			interrupt-names = "interrupt";
			interrupts = <0 95 4>;
			reg = <0x0 0xb0030000 0x0 0x10000>;
			reset-gpios = <&gpio 80 1>;
			xlnx,dma-addr-width = <32>;
			xlnx,dma-align = <16>;
			xlnx,max-height = <576>;
			xlnx,max-width = <720>;
			xlnx,pixels-per-clock = <2>;
			xlnx,s-axi-ctrl-addr-width = <0x7>;
			xlnx,s-axi-ctrl-data-width = <0x20>;
			xlnx,vid-formats = "rgb888", "bgr888", "xbgr8888", "xrgb8888", "xbgr2101010", "uyvy", "y8", "y10", "vuy888", "xvuy8888", "yuvx2101010", "yuyv", "nv12", "nv16", "xv20", "xv15";
			xlnx,video-width = <10>;
		psu_ctrl_ipi: PERIPHERAL@ff380000 {
			compatible = "xlnx,PERIPHERAL-1.0";
			reg = <0x0 0xff380000 0x0 0x80000>;
		psu_message_buffers: PERIPHERAL@ff990000 {
			reg = <0x0 0xff990000 0x0 0x10000>;
		sdi_rx_input_v_frmbuf_wr_0: v_frmbuf_wr@b0000000 {
			#dma-cells = <1>;
			interrupts = <0 92 4>;
			reg = <0x0 0xb0000000 0x0 0x10000>;
			reset-gpios = <&gpio_resets_axi_gpio_resets 1 0 1>;
			xlnx,fid ;
			xlnx,max-height = <1080>;
			xlnx,max-width = <1920>;
		sdi_rx_input_v_proc_ss_0: v_proc_ss@a0080000 {
			clock-names = "aclk_axis", "aclk_ctrl";
			clocks = <&zynqmp_clk 72>, <&zynqmp_clk 71>;
			compatible = "xlnx,v-proc-ss-2.1", "xlnx,v-vpss-scaler-1.0", "xlnx,vpss-scaler";
			reg = <0x0 0xa0080000 0x0 0x40000>;
			reset-gpios = <&gpio 78 1>;
			xlnx,colorspace-support = <0>;
			xlnx,csc-enable-window = "true";
			xlnx,enable-csc = "true";
			xlnx,h-scaler-phases = <64>;
			xlnx,h-scaler-taps = <8>;
			xlnx,max-num-phases = <64>;
			xlnx,num-hori-taps = <8>;
			xlnx,num-vert-taps = <8>;
			xlnx,pix-per-clk = <2>;
			xlnx,samples-per-clk = <2>;
			xlnx,scaler-algorithm = <2>;
			xlnx,topology = <0>;
			xlnx,use-uram = <0>;
			xlnx,v-scaler-phases = <64>;
			xlnx,v-scaler-taps = <8>;
			scaler_ports: ports {
				#size-cells = <0>;
				scaler_port0: port@0 {
					/* For xlnx,video-format user needs to fill as per their requirement */
					reg = <0>;
					scaler_in: endpoint {
						remote-endpoint = <&sdi_rx_out>;
				scaler_port1: port@1 {
					reg = <1>;
					scaler_out: endpoint {
						remote-endpoint = <&vcap_csi_in>;
		sdi_rx_input_v_smpte_uhdsdi_rx_ss: v_smpte_uhdsdi_rx_ss@a0030000 {
			clock-names = "sdi_rx_clk", "video_out_clk", "s_axi_aclk";
			clocks = <&misc_clk_0>, <&zynqmp_clk 72>, <&zynqmp_clk 71>;
			compatible = "xlnx,v-smpte-uhdsdi-rx-ss-2.0", "xlnx,v-smpte-uhdsdi-rx-ss";
			interrupt-names = "sdi_rx_irq";
			interrupts = <0 89 4>;
			reg = <0x0 0xa0030000 0x0 0x10000>;
			xlnx,exdes-board = "ZCU106";
			xlnx,exdes-config = "Pass-Through";
			xlnx,include-adv-features = "false";
			xlnx,include-axilite = "true";
			xlnx,include-edh = "true";
			xlnx,line-rate = "12G_SDI_8DS";
			xlnx,pixels-per-clock = <0x2>;
			xlnx,video-intf = "AXI4_Stream";
			sdirx_ports: ports {
				#size-cells = <0>;
				sdirx_port: port@0 {
					/* Fill the fields xlnx,video-format and xlnx,video-width based on user requirement */
					reg = <0>;
					xlnx,video-format = <0>;
					sdi_rx_out: endpoint {
						remote-endpoint = <&scaler_in>;
		misc_clk_0: misc_clk_0 {
			#clock-cells = <0>;
			clock-frequency = <148500000>;
			compatible = "fixed-clock";
		vcu_0: vcu@a0100000 {
			#clock-cells = <1>;
			#size-cells = <2>;
			clock-names = "pll_ref", "aclk", "vcu_core_enc", "vcu_core_dec", "vcu_mcu_enc", "vcu_mcu_dec";
			clocks = <&zynqmp_clk 73>, <&zynqmp_clk 71>, <&vcu_0 1>, <&vcu_0 2>, <&vcu_0 3>, <&vcu_0 4>;
			compatible = "xlnx,vcu-1.2", "xlnx,vcu";
			interrupt-names = "vcu_host_interrupt";
			interrupts = <0 96 4>;
			ranges ;
			reg = <0x0 0xa0140000 0x0 0x1000>, <0x0 0xa0141000 0x0 0x1000>;
			reg-names = "vcu_slcr", "logicore";
			reset-gpios = <&gpio 119 0>;
			encoder: al5e@a0100000 {
				compatible = "al,al5e-1.2", "al,al5e";
				reg = <0x0 0xa0100000 0x0 0x10000>;
			decoder: al5d@a0120000 {
				compatible = "al,al5d-1.2", "al,al5d";
				reg = <0x0 0xa0120000 0x0 0x10000>;
		vcap_mipi {
			compatible = "xlnx,video";
			dma-names = "port0";
			dmas = <&mipi_csi2_rx_v_frmbuf_wr_0 0>;
			vcap_mipi_ports: ports {
				#size-cells = <0>;
				vcap_mipi_port: port@0 {
					direction = "input";
					reg = <0>;
					vcap_mipi_in: endpoint {
						remote-endpoint = <&csiss_out>;
		vcap_sdi {
			dmas = <&sdi_rx_input_v_frmbuf_wr_0 0>;
			vcap_ports: ports {
				#size-cells = <0>;
				vcap_port: port@0 {
					reg = <0>;
					vcap_csi_in: endpoint {
						remote-endpoint = <&scaler_out>;
Ip Integrator Diagram
If I don't put the AXI4Stream Subset Converter between csi rx and fb wr ip's, pl.dtsi doesn't even include vcap_csi. That is probably because of line 72 at https://github.com/Xilinx/device-tree-xlnx/blob/73e546e312a22d7fb410c28d5c79174d2eb29938/mipi_csi2_rx/data/mipi_csi2_rx.tcl
Even after expected pl.dtsi output is generated, xilinx-video driver fails to parse the devicetree. No /dev/video* , /dev/media*, /dev/v4l-subdev* entry is generated for the mipi blocks. My MIPI TX is a ADV7280M with a analog video as the main video source, so I don't need all the post processing ips in the reference design.
Visitor omerfirmak
Re: xilinx-video driver fails at graph parsing
Also,
When I try to launch a gstreamer pipeline with v4l2src I get the following error, even with prebuilt reference design images on my ZCU106 board.
root@zcu106_vcu_trd:~# GST_DEBUG=2 gst-launch-1.0 v4l2src device=/dev/video1 io-mode=4 ! video/x-raw, width=640, height=480 ! fakesink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
0:00:00.061930748  2872   0x5597999400 WARN                    v4l2 gstv4l2object.c:3141:gst_v4l2_object_save_format:<v4l2src0> format NV16_10LE32 has a pstride of 0, cannot compute padded with
New clock: GstSystemClock
0:00:00.128063365  2872   0x5597999400 ERROR         v4l2bufferpool gstv4l2bufferpool.c:677:gst_v4l2_buffer_pool_streamon:<v4l2src0:pool:src> error with STREAMON 22 (Invalid argument)
0:00:00.128104730  2872   0x5597999400 ERROR             bufferpool gstbufferpool.c:564:gst_buffer_pool_set_active:<v4l2src0:pool:src> start failed
0:00:00.128141683  2872   0x5597999400 WARN                 v4l2src gstv4l2src.c:697:gst_v4l2src_decide_allocation:<v4l2src0> error: Failed to allocate required memory.
0:00:00.128167136  2872   0x5597999400 WARN                 v4l2src gstv4l2src.c:697:gst_v4l2src_decide_allocation:<v4l2src0> error: Buffer pool activation failed
0:00:00.128253304  2872   0x5597999400 WARN                 basesrc gstbasesrc.c:3275:gst_base_src_prepare_allocation:<v4l2src0> Subclass failed to decide allocation
0:00:00.128346094  2872   0x5597999400 WARN                 basesrc gstbasesrc.c:3055:gst_base_src_loop:<v4l2src0> error: Internal data stream error.
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory.
0:00:00.128374826  2872   0x5597999400 WARN                 basesrc gstbasesrc.c:3055:gst_base_src_loop:<v4l2src0> error: streaming stopped, reason not-negotiated (-4)
Additional debug info:
../../../git/sys/v4l2/gstv4l2src.c(697): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Execution ended after 0:00:00.066174632
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
root@zcu106_vcu_trd:~# GST_DEBUG=2 gst-launch-1.0 v4l2src device=/dev/video0 io-mode=4 ! video/x-raw, width=640, height=480 ! fakesink
0:00:00.060769232  2869   0x557f918950 WARN              v4l2_media gstv4l2media.c:252:gst_v4l2_media_refresh_topology: /dev failed to fetch topoplogy info: Inappropriate ioctl for device
0:00:00.061430808  2869   0x557f928800 WARN                 basesrc gstbasesrc.c:3055:gst_base_src_loop:<v4l2src0> error: Internal data stream error.
0:00:00.061469251  2869   0x557f928800 WARN                 basesrc gstbasesrc.c:3055:gst_base_src_loop:<v4l2src0> error: streaming stopped, reason not-negotiated (-4)
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
../../../../git/libs/gst/base/gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
ERROR: pipeline doesn't want to preroll.
Visitor librabryant
I also meet the issue. Do you have any update?
The default assuptoin at this time is that the MIPI CSI2-RX outputs Bayer formated data, which isn't a valid input for the Video Fame Buffer.  And even if the Video Frame Buffer did support it, it is not a valid format for the VCU, which needs to have a YUV formated input.  You can find more information in PG252 in the Source Frame Format section.
The expectation is that your MIPI CSI2-RX Pipeline will look like the one in the ZCU106 Zynq UltraScale+ MPSoC VCU TRD and this is how the Device Tree Generator (DTC) will automically generated device tree.  So if you have a differnt configuration you will have to modify your device tree to descript your configuration.
MIPI CSI2 Rx -> Demosaic -> Gamma LUT -> VPSS CSC -> VPSS Scaler -> Video Frame Buffer Write IP
NOTE:  The output of the Demosaic is RGB and then you use the VPSS CSC to convert it to YUV format, which is what the Zynq UltraScale+ MPSoC VCU is expecting.
In your case you are not getting data from a camera, but rather the output of a ADV7280M.  The data sheet for the say "The ADV7280-M outputs video data in an 8-bit YCrCb 4:2:2 format."
According to the documenation for the MIPI CSI2-RX Driver on the Xilinx Wiki, there is support for 8-bit YUV 4:2:2, but you will need to make sure you declare that this is the output format in the device tree.  So you should be able to modify the device tree to declare that the output format is 8-Bit YUV 4:2:2 format, which is a valid input for the Video Frame Buffer.
Chris
Video Design Hub | Embedded SW Support
Visitor omerfirmak
@chrisarThank you.
I have managed to get a /dev/media and /dev/v4lsubdev entry after setting up the ADV7280 device tree and driver.  Do I really need to specify the output format of ADV7280M, isn't the input and output video formats confgured in the runtime?
My current pipeline looks like this;
root@zcu106_vcu_trd:~# xmedia-ctl -p
Media controller API version 4.19.0
Media device information
driver          xilinx-video
model           Xilinx Video Composite Device
serial
bus info
hw revision     0x0
driver version  4.19.0
Device topology
- entity 1: vcap_mipi output 0 (1 pad, 1 link)
            type Node subtype V4L flags 0
            device node name /dev/video0
        pad0: Sink
                <- "a0000000.mipi_csi2_rx_subsystem":0 [ENABLED]
- entity 5: adv7180 15-0020 (1 pad, 1 link)
            type V4L2 subdev subtype Decoder flags 0
            device node name /dev/v4l-subdev0
        pad0: Source
                [fmt:UYVY8_2X8/720x240@1001/30000 field:alternate colorspace:smpte170m]
                -> "a0000000.mipi_csi2_rx_subsystem":1 [ENABLED]
- entity 7: a0000000.mipi_csi2_rx_subsystem (2 pads, 2 links)
            type V4L2 subdev subtype Unknown flags 0
            device node name /dev/v4l-subdev1
        pad0: Source
                [fmt:SRGGB8_1X8/1920x1080 field:none colorspace:srgb]
                -> "vcap_mipi output 0":0 [ENABLED]
        pad1: Sink
                <- "adv7180 15-0020":0 [ENABLED]
How should I proceed?
ADV7280M driver doesn't really expose much to userspace, the API calls it exposes are not supported by the v4l2-ctl version that comes with petalinux 2019.1. Even how to do analog input selection is not clear.
Visitor librabryant
@omerfirmak: I suggest you chenck your pl.dtsi which is generated by petalinux build. I guess that the driver of "entity 7: a0000000.mipi_csi2_rx_subsystem" is only supportting the fmt:SRGGB8_1X8. I'm trying to typing the command to change the fmt. There is no error back to the consol. You can use the following command to test it. media-ctl -d /dev/media0 -V "\"a0000000.mipi_csi2_rx_subsystem\":0 [fmt: YUYV/1920x1080 field:none]" @CHRIS If I'm wrong, please correct me. Best Regard, thank you! Librabryant
Visitor omerfirmak
@librabryantpl.dtsi is as attached in the first post. Yes, it does show rgb only as pixel format. I think this should have been handled by the Xilinx tools, as I have already selected the pixel format (YUV 4:2:2 8 bit) in the Vivado design. Do you know how I can add the support for my particular setup? The documentation is really lacking, there is no doc on possible configurations that can go in to device tree entry.
@chrisardo you have any suggestions?
Scholar watari
Hi @omerfirmak
I suggest you to make sure capability.
Would you make sure capability of each device by gst-device-monitor-1.0 ?
You can understand how to set it.
Hi @omerfirmak
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
